Help please! Removing double sided tape?
Chuk85
Post by Chuk85 »
So I took off my rubbing strips to be painted but getting the remainder of the old double sided tape used to stick them on with is becoming a nightmare.
I have tried using the hairdryer to heat it up , hot water, windowleen even meths and nothing's making it any easier.
Have you guys got any tips please?
tommyzooom
Re: Help please! Removing double sided tape?
Post by tommyzooom »
A "Caramel wheel" in a cordless drill is what you need, and some tar and glue remover for any remaining residue.
Beaker2135
Post by Beaker2135 »
Try isopropyl alcohol or acetone, cellulose thinners is not so good
Shane1987
Post by Shane1987 »
Wd40
d.e.hill
Post by d.e.hill »
When it's really sticky, and nothing else works, you need a can of Multisolve.
Made by the same people that make CT1 sealants, it's magic!
Gresley
Post by Gresley »
If you use a brand new caramel wheel be very careful as its easy to burn the paint.
Barbel330
Post by Barbel330 »
I wouldn't recommend a caramel wheel unless you want to repaint your panels. It's a horrible job but you just have to keep applying chemicals (I use degreaser or thinners) and rubbing your finger prints off.
Instagram: @y_5cuf
Chuk85
Post by Chuk85 »
Thanks a lot guys. You've been a great help!
Padster
Post by Padster »
I found big wipes are good for getting off the leftovers of sticky on my ex bg van :D
wheelfurb
Post by wheelfurb »
I've always used a caramel wheel. Works wonders.... takes a couple of mins. Is it bad for the paintwork?
tommyzooom
wheelfurb wrote: Wed Jul 26, 2017 10:52 pm I've always used a caramel wheel. Works wonders.... takes a couple of mins. Is it bad for the paintwork?
Only if you run it too fast, and/or hold it on until it burns the paint :roll:
