Sub mounting
Sub mounting
Evenin. Daft question maybe but can I mount my Focal iBus 20 on something rather than to the floor of my 2013? Any suggestions welcome. Cheers guys.
Re: Sub mounting
Not really many options. What is the focal ibis like for output? I keep eying it up for my van
Re: Sub mounting
Pretty sweet but the guy who installed it put it in so the controls are right up against the drivers sill so I cant tune it properly. Hence trying a different method as hes already put two screw holes through the floor...
Re: Sub mounting
If it's just because you can't get too the controls I would personally takenthe screw out, drill them slightly bigger and insert rivnuts. Then you can easily bolt it down after you set gains Ect which once the gain and crossovers are set, you will never have too touch again in all fairness.
I would also add a rubber washer between the floor and the sub. Just too add a little vibration dampening
Re: Sub mounting
Cheers!
