17s or 18inch wheels?
- Beaker2135
Re: 17s or 18inch wheels?
There shouldn't be any difference if you fit the right tyres. Overall diameter, rolling circumference and ride height should all be, more or less, the same
Some examples depending on wheel width
195/65R15
205/55R16
225/45ZR17
255/30R19
Wheel and tyre size calculator
https://www.wheel-size.com/calc/?wheel ... mm&sr=0mm
195/65R15
205/55R16
225/45ZR17
255/30R19
I'm looking for the interlagos vw scirocco wheels 18 they are but I was concerned about fuel consumption as I'm happy with it now..
Sent from my F3211 using Tapatalk
Guys what tyres are you running with the 18s? Can you put 45/18 or would that look stupid
Lads a quick question what tyres should you run with 18inch wheels. Is it 225/40/18 or can I go for 225/45/18?
- torque777
I run 225-40-18 if you go to next size then I believe it's 235-45-18
I'm running 18s with 225 40 18 and it's really smooth even though it's lowered I'd 100% go with 18s
A friend of mine is running 19s they just look to big
running 18s.
very nice ride
very nice ride
It will look great lowered. How many mm are you going to lower it by?
Cheers guys for the feedback 18s it is
Yes I think that's enough. I had mine lowered yesterday and went for 60mm. Still got standard wheels at the moment but I'm picking some 18" wheels up this week and having it colour coded at weekend
What hole setting did you use for the shackles in the back mate?
- Chris017
I am one hole from the top and it's hitting something on the back end. I think the shackle is bending with the leaf spring and hitting the body on the top. My mate had a issue with his connect and just grinder a notch out and was fine.
Anyone had this issue
