Bi-Xenon Retrofit for Caddy 4
owencardew
Re: Bi-Xenon Retrofit for Caddy 4
Post by owencardew » Fri Aug 25, 2017 11:50 pm
stan-the-man wrote:
Fri Aug 25, 2017 4:54 pm
No level sensors were ever fitted to caddy 4 and there's no reason to do so.
Only if it's FL caddy of course 2010-2015
Stan-The-Man,
I don't doubt your advice where you said the Bi-Xenon Lights are a 10-Pin, but this guy here (
https://www.caddy2k.com/forum/viewtopic ... 22#p262422 ) in his write-up said he used a 10-Pin to 12-Pin Adapter... He doesn't specify which side he used the 12 Pins on and which side the 10 Pins are on, but just wanted to ask you if it would be possible for you to post a photo of the connector on your Bi-Xenons, just to compare?
Sorry to be a pain in the neck! Just want to make sure i have absolutely everything covered because ordering parts from UK and having them sent to me in Malawi is a lengthy process, i don't want to be sitting looking at Bi-Xenons in my garage waiting for something silly to arrive! :D
2016 Caddy Maxi 2.0 TDI DSG with RaceChip Pro 2. 18" Santiago Alloys with 235/45R18 Tyres, Smoked Tail Lights, Stainless Steel Pedals. Now installing OEM Bi-Xenon Headlights, Linearus Dash Trim, MFSW & More...
stan-the-man
Post by stan-the-man » Sat Aug 26, 2017 9:21 am
I don't get it as both headlights use same plug - 10 pin 6R0973735
I checked both halogen and gas discharge. I will try to get a pic of my plug later on.
owencardew
Post by owencardew » Sun Sep 10, 2017 9:45 am
Hi Stan-The-Man,
You were right - it is 10-Pin to 10-Pin.. Dunno where they other guy got the 12-Pin idea, but i managed to get everything to work!
Is your Caddy a Highline? IF so, please could you post one of your VCDS Scans, I'm trying to do the Multi-Function Steering wheel but theres zero info on doing it for a Caddy 4 and i want to be sure i get the right modules....
Thanks! :D
stan-the-man
Post by stan-the-man » Sun Sep 10, 2017 12:58 pm
Good stuff buddy!
I posted a screenshot of my steering wheel details in your other thread
Adamkane
Post by Adamkane » Tue Apr 24, 2018 8:24 pm
Hi I’m New on here I’ve recently purchased a lovely vw caddy highline in metallic black with all the factory extras on apart from the bi-xenon headlights with led DRLs to which I believe can be retrofitted it’s a mk4 2016 150 dsg highline, could you help me in what I need to get this?
lord-dudester
Post by lord-dudester » Sun Apr 29, 2018 8:27 pm
hi mate, I've been planing to do the same for sometime, I'm gonna get round to it soon. what years your van? if its a new one, its just the headlights, ballast and bulbs, then coding
Dutchcaddys
Post by Dutchcaddys » Thu Dec 06, 2018 8:58 pm
Guys,
We are trying to retrofit the Xenon headlights in a 2018 Caddy.
Does anybody have a description for us? or de VCDS coding?
We can make everything work except for the LED strip.
At this moment the caddy is a trend line.
I have tried using the link to another part of this forum but it wouldn't work.
any help would be great.
Best regards from Holland!
lord-dudester
Post by lord-dudester » Fri Dec 07, 2018 9:43 pm
Should find what you need here in the how to thread, coding etc is all there
http://caddy2k.com/forum/viewtopic.php?f=22&t=29192
Jefinabox
Post by Jefinabox » Sun Dec 09, 2018 2:27 pm
These look so good, shame they're not that powerful. Still, gonna have to save up for some..
