Installing windows and rear seats
phil2144
Re: Installing windows and rear seats
Post by phil2144 » Thu Feb 15, 2018 9:24 pm
The drilling and cutting should not be a problem as drilled plenty of holes in aircraft and have a dremel that will cut anything even jammed in road springs :shock: .
As for seats will touran fit the mounting plate or any others?
Do you have any pictures of the rear mounts and as for the trims any part numbers?
Andy1234
Post by Andy1234 » Thu Feb 15, 2018 9:32 pm
No sorry the only seats that fit is the caddy life ones as the floor plate is from the life not the Touran.
People have fitted the floor pan from the Touran but I went down the factory look, as you can get all the plastic trims off the shelf and no modifications needed.
The Touran seats are all individual and looked to be more in-depth fabrication and harder seat belt locations.
phil2144
Post by phil2144 » Thu Feb 15, 2018 9:39 pm
Noted, its just the availability of the caddy life seats over the touran ones. Would the floor pan require much adjustment for the touran seats?
Andy1234
Post by Andy1234 » Thu Feb 15, 2018 9:46 pm
It’s completely different mate
You would need the 2x floor plates that you will have to cut out the Touran as you can’t buy them off the shelf
Andy1234
Post by Andy1234 » Thu Feb 15, 2018 9:55 pm
Rear caddy life seats on eBay now for buy it now of £280 with all fixings, then all you need is the outer seat belts and your sorted.
phil2144
Post by phil2144 » Thu Feb 15, 2018 10:02 pm
The pictures make more sense, could the caddy floor pan be modded to take the touran floor pan fittings then again at £280 for the set that sounds good.
Andy1234
Post by Andy1234 » Thu Feb 15, 2018 10:05 pm
Yes mate loads of people have done them as they are 3x single seats
The eBay item number is
192452479267 For caddy life stuff
Cbaker9076
Post by Cbaker9076 » Fri Feb 16, 2018 11:32 am
Hi do you have any pictures of how you did the bottom seatbelt brackets and where you drilled the holes thanks
Andy1234
Post by Andy1234 » Fri Feb 16, 2018 12:28 pm
Sorry no pics mate
I drilled in the standard location and had some bolts, spaces made by a friend, so that it didn’t crush the chassis box section. I will take some pics when I get chance.
phil2144
Post by phil2144 » Sat Feb 17, 2018 10:38 am
Andy1234 where did you get the sill trim part from? If it was VW do you have the part number?
Andy1234
Post by Andy1234 » Sat Feb 17, 2018 12:01 pm
It’s all form the scrap yard mate.
That’s the main reason I went down the factory (caddy life) look, because everything is readily available.
And sorry I don’t have any part numbers.
I would have to pull my van apart to get them.
welf
Post by welf » Thu Sep 06, 2018 10:50 am
First post here and this is exactly the kind of information I'm looking for!
I have a 2013 and have go hold of some standard rear seats, mounting brackets and seat belts. What I don't have yet is the panel (2K0 802 277) or anything that sits on the other side of the chassis or pillars. Now I have the part number for the panel I'm sure I can pick one up (any recommended dealers?).
Are there specific part numbers for the nuts that go on the underside of the floor plan? and/or for the load spreading parts the upper and lower seatbelt mounts bolt in to?
Many thanks!
SnoWhite
Post by SnoWhite » Sat Sep 08, 2018 5:14 pm
Might want to visit TPS Trade Part Suppliers (Provide parts to VAG and trade outlets) at a quiet time - so not first thing AM or just before they shut. Most will serve non trade if you pay cash, and every time I have needed parts, they have been happy to dig out diagrams to identify and order whatever you need.
However most parts systems now use the VIN details/number plate info which will therefore only show stuff officially installed on your vehicle . So if you are planning to add "extra" stuff - a good trick is to visit a VW dealers and write down the number plate of a similar year caddy model which does have what you want installed. So for fixings for rear seats, look around for a crew cab or combi/life model. Don't forget SWB/Maxi as appropriate, which will then show up whatever reinforcing plates and fixings may be needed.
willhouse
Post by willhouse » Sun Sep 09, 2018 9:59 am
I have been following a few threads on this recently as I am currently putting rear seats in my 4 motion.
I have a genuine set of Kombi seats. After eyeballing the bolt locations for seats and belts we found that captive welded nuts were already on the floor pan, the floor just needed drilling to bolt the seats and belts in.
I was wondering if everyone has had to do the 'floor spacer anti-crush' tube for the belt mounts, or have other people found the same as me?
PS.... if anyone has a maxi rear genuine rubber footwell set including the side trims and bulkhead delete parts Iwould gladly buy them!
duncan
Post by duncan » Fri Jan 11, 2019 6:31 pm
Andy1234 wrote:
Fri Dec 15, 2017 5:39 pm
The vw panel £52.00 part no. 2K0 802 277
That’s the panel you need to mount the new front part of the seats after drilling out the old floor pan.
Then all the rest was a buy from a local scrap yard, front and rear carpets, side plastic trims, 2x outer seat belts, seats them selfs, all fixings, clips and bolts. Lad was fantastic in the scrap yard. He gave me everything possible and some extra stuff he thought I might need.
I did the seats over 2 days over 2 different weekends, the only problem I came across was the outer seat belt mounting points. This I had a local engineering company make some new bolts with sleeves so I didn’t crush the original chassis box section and was possible to mount to look factory.
Hi Andy,
Great job on your conversion. I’m just about to attempt my own and want a bit of advice.
Where did you source the part? £52 is way cheaper than I can find it. Also, what bonding did you use?
I would appreciate any info!
Thanks,
