I imagine this has been cover many times before but until I can see the full forum I'm a bit stuck!
Is the correct fuse 25amp and it's position 47. I have tried this already but no luck The van is a 2013 facelift start line maxi.
Any help is much appreciated
Martin
Cigarette lighter fuse.
Re: Cigarette lighter fuse.
I have same issue mate!
Climb Mountains not so the world can see you, but so that you can see the world....
Well I fixed it. The guy who took the tracker out for the previous owner must of disconnected the plug on the back of the lighter! Simple fix!
