1.6 injector problem
Is this specific to a year or is the 1.6 range please? TIA
Re: 1.6 injector problem
1.6TDI 2010-2013 tend to suffer the most from the failure of the injector electric coil. I take it this is the problem you are referring to?
Think so. Im looking at getting a caddy and was put off by how many people are having problems with injectors on the 1.6 but i didnt know whether it was year or model specific. So the 2010-2013 is the problem model
For injector electrical failure, yes.
There are other injector failures such as blockages and wear but these are less common.
If you get a caddy and your fear for the injectors, it's worth noting that VW will give a 2 year extension on engine emission related parts (injectors, EGR valve, etc.) if you have the emissions update carried out to remove the "cheat" software.
So im looking at getting a caddy maxi and if i got 2014 onwards it's less likely to get a injector problem?
Yep.
Thqnks doc that will widen my search alot. To be honest ive been struggling to find a 2.0 maxi i like so now i can get the 1.6 version will help massively
Doc whats your view on the software fix? I've just had one die on the motorway. Thinking of getting that one fixed and then maybe getting the emissions update for the warranty work. However other people are saying don't get this fix as it causes more issues (even if under warranty) Other option is swap them all and pay myself.
2011 1.6 TDI - ex british gas caddy maxi http://caddy2k.com/forum/viewtopic.php?f=3&t=30795
Mk4 rear lights, Auto headlights, Passat w8 interior leds, 18" supermetal bullets, Polo MFSW, Touran doorcards exit lights, carpet sports seats & storage bases. VanX glovebox, Audi air vents, Sirus rear seat conversion, Privacy rear windows, RCD 330 CarPlay, Speakerupgrade underseat sub, Leisure battery, 3000w inverter.
Join the Facebook group , Volkswagen Diesel Customer Forum ( emissions scandal ) group to learn about all the software fix problems people are having .dopeytree wrote:Doc whats your view on the software fix? I've just had one die on the motorway. Thinking of getting that one fixed and then maybe getting the emissions update for the warranty work. However other people are saying don't get this fix as it causes more issues (even if under warranty) Other option is swap them all and pay myself.
