Hello people, I would like to wire in an extra L.E.D strip in the rear load space, but using the original wiring so it works when the door opens.
There is 3 wires to the rear lamp
Red with purple
Blue with white
Brown
Any help would be gladly appreciated
Thank you
Help to wire in L.E.D lights please
Re: Help to wire in L.E.D lights please
If you wire into the original light, you can retain the switch function and turn the light on manually if needed.
There are bulb adaptors available that fit just like a bulb and give you two wire tails to connect onto.
Thank you, you are a genius.
Ordered 2 sets from eBay
Hello Andy1234, Doc what do you call the adapters as I would like that sort of setup. I've been looking on fleabay but nothing's really coming up thanks.
Hello mate this is what I orderedRustybullet wrote: ↑Sat Sep 23, 2017 5:12 pm Hello Andy1234, Doc what do you call the adapters as I would like that sort of setup. I've been looking on fleabay but nothing's really coming up thanks.
eBay item no.
281933722852
Hope this help
Thanks Andy1234, i'll have a look at them.
