Any one got a dash swap how to or top tips? Not got permission yet for the how to section and the Touran dash will be here next week
Dash swap
Re: Dash swap
I'm looking to do this myself, by the looks of it you need the brackets and vents from the touran dash to match, other than that it's straight swap!
- brooneye
Re: Dash swap
There is a build thread that I used, search woody’s woody, that has pictures on how to do this. Make sure you have all the parts needed. I found out that caddy parts can’t be used so had to make a second trip to the breakers
Re: Dash swap
The dash swap is easy enough.. just take your time.. you will need the vents and the brackets too. I did mine in around 3 hours..
Re: Dash swap
Great, thanks chaps.Mrmatty wrote:The dash swap is easy enough.. just take your time.. you will need the vents and the brackets too. I did mine in around 3 hours..
Re: Dash swap
Looking at swapping to a caddy 4 dash. Anyone tackled that yet??
Re: Dash swap
Could be intresting.. i would have thought it will drop in nicely
