Ran VCDS on the van for the first time since tinkering. Quite alarming at first. Managed to clear off the codes that I know were caused by removal of seats / airbag / steering wheel etc
Having difficulty with a few bits and wondered if anyone can help with the following problems...
Since fitting my new head unit the OPS doesn't work. I get a long beep when putting into reverse. I have also fitted an aftermarket reverse camera. I found a check box to enable this but it wouldn't accept the coding due to 'security' (not sure what that even means!)
Also had difficulty getting into the Central Convenience module but have read disconnecting the battery will reboot so will try that in the morning. Assume the setting for heated seats is in here as couldn't find it in central electrics!
Finally, although my caddy is a highline it seems to have a midline cluster unless I'm mistaken and there is a way to enter the settings somehow? Also I have fitted a MFSW but need a MFSW airbag loom, is it possible my steering module and slipring will be ok for this, or is there a way I can find the correct part numbers using my existing module numbers?
Thanks in advance for any help
VCDS Scan below...
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZGX124274 Mileage: 14710km-9140miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-DFSD) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 GT HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1774
Revision: 8AH20---
Coding: 0111001204250D090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01104L906016GT 001003
ROD: EV_ECM20TDI01104L906016GR_001_VN35.rod
VCID: 0108BD9890090B4E85-8054
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 40756000000433
Coding: 1079409B9264A4820877027D498625E37900F0
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
VCID: 3F8C7B60A67DBDBEB3-806A
1 Fault Found:
0297 - Steering angle sensor
B1168 54 [008] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Reset counter: 117
Mileage: 11257 km
Date: 2017.01.24
Time: 00:20:39
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000001002
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW32.rod
VCID: 3D700168AC71AFAEA1-8068
1 Fault Found:
9481200 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 132
Mileage: 14718 km
Date: 2017.10.11
Time: 16:42:49
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+ 122 0183
Revision: BD122001
Coding: 491A583EC037E16A08880082940001640351000842228260648087000041
Shop #: WSC 35110 377 00146
VCID: 73E4E750D2B529DE87-8026
Subsystem 1 - Part No: 2K2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 03031 26 0512
Coding: 009795
Subsystem 2 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 100316 03 37 0059
Coding: 0228DD
Subsystem 3 - Part No: 7N0 951 172
Component: Sensor, DWA 0 005 0502
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 1K8 919 465 HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0479
Revision: -------- Serial number: 39291606403471
Coding: 0001050001
ASAM Dataset: EV_EPHVA14VW364GP00 001006
ROD: EV_EPHVA14VW364GP00.rod
VCID: 76E2DE44C9C73CF6A0-8022
1 Fault Found:
1079058 - Center Rear Left Parking Aid Sensor
B1077 12 [008] - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 117
Mileage: 14247 km
Date: 2017.08.22
Time: 00:26:59
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 2K5 959 655 HW: 2K5 959 655
Component: VW10Airbag019 008 0016
Revision: -------- Serial number: 003QV001WAGX
Coding: 000000000000000000000000000000003139
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 79F8D578F8D9538ECD-802C
Crash sensor for side airbag: driver side:
Serial number: 3497ARB405J3U9U4393I
Crash sensor for side airbag: front passenger side:
Serial number: 3507ARB405J3U47EC11Y
1 Fault Found:
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [136] - Resistance Too High
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 14245 km
Date: 2017.07.30
Time: 21:15:16
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 CL HW: 5K0 953 569 BB
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20160304200615
Coding: 4080160010
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 2K5 920 966 A HW: 2K5 920 966 A
Component: KOMBI H04 1009
Serial number: 00000000000000
Coding: 480A001200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VN35.rod
VCID: 336427509A3569DE47-8066
1 Fault Found:
13654544 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 132
Mileage: 14718 km
Date: 2017.10.11
Time: 17:06:16
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BE HW: 7N0 907 530 AL
Component: J533 Gateway H58 1673
Revision: H58 Serial number: 160316F1002270
Coding: 357421
VCID: 74E6E44CD7BB2EE69E-8020
3 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 18
Reset counter: 171
Mileage: 14249 km
Time Indication: 0
Date: 2017.09.03
Time: 00:00:02
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 168
Mileage: 14249 km
Time Indication: 0
Date: 2017.09.04
Time: 09:29:06
03158 - Control Module for Information Electronics 1 (J794)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 14249 km
Time Indication: 0
Date: 2017.09.04
Time: 09:29:10
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 1009
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADAFA348D7FE81634-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2144
Coding: 0131632
VCID: 71E8ED5868A91BCE75-8024
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 397815787059938E8D-806C
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0131632
VCID: 72EAE2546DAF20D68C-8026
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1673
Coding: 030F1873
VCID: 71E8ED58A8A91BCE75-8024
Subsystem 1 - Part No SW: 1K0 915 181 K HW: 1K0 915 181 K
Component: J367-BDM H07 0223
Serial number: 43069835248761720259
End-------------------------(Elapsed Time: 02:32)--------------------------
VCDS Faults Help Please
- Whitey
Re: VCDS Faults Help Please
Hi mate. If i remember correctly to sort the steering angle sensor problem you need to do 2 or 3 full lock to lock cycles for the angle sensor to find out where it is again.
Also my van is a highline but only has the low/midline clocks so I can't get into any type of settings menu which is a pita! Apparently only the highline clusters have the settings menu. :/
Going off your steering wheel module number i dont think it supports mfsw as its midline sure someone with better knowledge will confirm as i am no expert
- Whitey
Thanks for the reply Bert. I will do the steering lock test tomorrow. Yeah pretty disappointing having the midline cluster, assumed the highline cluster would be standard on a highline model, was hoping there was some trick to activate the menu but wishful thinking i suppose!
- Whitey
Thanks Andrew5. Thought this may be the case but had fingers crossed it would be compatible. I think there's a way I can cross reference the old part vs new part needed on RossTech... somehow
- Whitey
Ok, just had a bit of a look around the rosstech site
My steering module is 5K0 953 569 BB
Think I need a 5K0 953 569 BA for the mfsw...
Any help gratefully appreciated
EDIT: or is that the stalk set? oh dear!
