How to carpet back of van
I am looking at carpeting the roof and walls of van but need as much help and info as possible. Is there any good videos or pictures step by step guides.
Is it best to ply line the walls from floor tight up to the roof and then glue the carpet to the ply.
The roof , does it get left and then glue carpet straight to that covering the clips as well ?
Re: How to carpet back of van
Hello Sibo, to get a good finish you need to remove the ply panels before covering with carpet.Sibo wrote: ↑Mon Oct 16, 2017 9:04 pm I am looking at carpeting the roof and walls of van but need as much help and info as possible. Is there any good videos or pictures step by step guides.
Also you may need to carpet the places on the sides of the van where the ply lining is not covering.
I will post some pics for you.
Hope this helps
Where are you based?
Thanks for the pictures, based in Newcastle-upon-Tyne.
Does the ply get screw then carpet attached after ?
I have carpeted then screwed the ply onto the side of the van, that way you can trim around all the edges of ply. Hope that helps
Your a little far from me mate, am now living in Norfolk or I could have helped you out.
Sorry to hijack your thread but what type of carpet are you using? Just the cheap acoustic stuff off fleabay or something better? Im wanting to do this to mine.
Going to get carpet from http://www.megavanmats.com/apps/webstor ... how/298422
Also have a ebay shop. Am not 100%on how to do it myself.
Hi andy1234, do you do that for a job ? As I m in Norfolk and looking to have my caddy done.
Hello Bert.c
Yes I use stuff off eBay from mega van mats
It stretches 4 ways and very forgiving.
Don’t forget to buy a good spray glue too.
Hello there Sifu
No it’s not my day job, have had experience with trimming before ( have been into car sounds systems ) you try and save money when ever you can!
Has your van been ply lined?
I don’t mind helping you out or your more than welcome to have a look at mine.
No mate not ply lined yet. Has plastic panels over the single skin bits. The thing I don't really get is how you carpet something that's not flat,like the wheels arches?
Hi Andy. I'm looking to carpet my solid bulk head and wondered if it's doable neatly. I mean will it stretch into all the curves etc. ?Andy1234 wrote: Hello Bert.c
Paul
I am going t do the same . Going to ply over the mesh in the bulkhead and then carpet both sides with accostic carpet, I might even fill the voids in between the mesh for better sound deadening
Cool. Just not sure how well the carpet will stretch into all the curves. Sure it's been done thoSibo wrote:I am going t do the same . Going to ply over the mesh in the bulkhead and then carpet both sides with accostic carpet, I might even fill the voids in between the mesh for better sound deadening
Should be ok. The carpet gets into the groves on the wheel arches
