Caddydaft wrote:Like it's been mentioned before, look for loose pipes, leaks, hose clips not tight, split hoses, fuel filter housing not making a seal etc etc.
Im just back from my holiday and went to start it and it struggled first turn but went the second and ran no problem
Hi. I have the same problem. Mine will fire off easy start and then run fine all day until the next morning. I am thinking injector seal leaking and getting fuel system air locked. Did u ever get to the cause? Thanks
Just a update. Fitted new injector seals over the weekend and now the van has started 1st turn every morning since. Fingers crossed it has sorted the problem.
Darranm wrote:Just a update. Fitted new injector seals over the weekend and now the van has started 1st turn every morning since. Fingers crossed it has sorted the problem.
I am a mechanic so did it myself. The seals cost me £20 off eBay a d some new stretch bolts from tps another £20.its not too bad a job if you are mechanical minded and got the tools.
Darranm wrote:I am a mechanic so did it myself. The seals cost me £20 off eBay a d some new stretch bolts from tps another £20.its not too bad a job if you are mechanical minded and got the tools.
Wish a was tbh can change the oil and that sort of stuff bit dont think ad try that
