Hi all,
Seen some limited info online and sure its common problem.
Each time I unlock the van, the side sliding door lock makes a horrendous noise! Like a fart!
Looking online it seems to be the teeth get worn on the mechanism, would this seem correct, and anyone know where the replacement part can be found?
Cheers!
Noisy Side Sliding lock
Re: Noisy Side Sliding lock
You're not alone, I have this issue too. SO loud!
Did you get it sorted?
