Sdi
Sdi
Hi guys new to the group just a quick question ive got a sdi 2.0 problem is if i park it on a hill it takes ages to start but if its flat its fine unsure wot it could be thanks
- Mk2kompressor
Re: Sdi
Air getting in the fuel lines.
Check the fuel filter housing is tight and go from there
2.Slow
Re: Sdi
Thank you
- D green
Re: Sdi
Most of the time it's the injector seals witch is a common problem with the SDI I had the same problem if I parked front facing down hill with at least half a tank and give it a small amount of throttle it would start no problem if not your left cranking for ages until it bleeds the air out
Re: Sdi
Thanks mate
