Caddy 2K Air Ride
Caddy 2K Air Ride
Hi guys,
Spoke with Doc earlier about putting a post up about this Caddy 2K Air Ride kit.
We have just finished this particular install so thought I'd post some pictures up and some information on the kit and see if anyone was interested!
Kit details on this van are as follows:
-Airlift Performance front struts, camber adjustable, damping adjustable and height adjustable (threaded bodies).
-Airlift 3H management with 1/4 lines.
-Intermotiv rear set up which has been tweaked slightly. This is using standard shocks.
The wheels are Vereinsport club ones, which are 18 x 8.5.
20171102_102401_preview by James Pallett, on Flickr
20171102_102427_preview by James Pallett, on Flickr
IMG-20171102-WA0021_preview by James Pallett, on Flickr
IMG-20171103-WA0014_preview by James Pallett, on Flickr
Enjoy!
Enjoy!
Re: Caddy 2K Air Ride
Welcome to the forum James.
The photos of that caddy have been doing the rounds on Instagram over the weekend, looks wicked.
- torque777
Any photos of the installation?
- brooneye
Welcome, nice looking van you have there. Agree with torque need some pictures of the install
- ozziecaddy
awesome looking van would love air ride on my caddy
Thanks for the compliments guys.
This isn't my van, it's a customers we have just finished up. Came in as a standard van with 2k on the clock. It's leaving with the air ride set up, full line out in the back and obviously the wheels.
If anyone wants some pricing on this kit I'd be happy to help!
Here is some pictures of the install, all installed under the van to maximize space inside!
20171102_082442_preview by James Pallett, on Flickr
20171103_092757_preview by James Pallett, on Flickr
Kit prices start from £3299 with V2 management and 1/4 lines.
And our fitting starts from £849
I'm about to drop my maxi on air does the intermotive kit fit the maxi? Or does it need modifying? I know I need airlift 55mm mk5/6golf front struts slam or performance, not sure which one to go for
Sent from my STF-L09 using Tapatalk
I have just had my van aired on the intermotive rear kit and had to be modified to suit a maxi. A few parts had to be altered/tweaked
Shorter shocks had to be used too.
Mk5 performance fronts where used to enable camber adjustment
- Maxi4life
Looks the dogs danglies that. If only I could throw another 5k at it I would.
Any pics or info what had to be tweaked?, for me the only issue I see with the intermotive kit is the structural strength where the boxsection has been notched under the axle, then all the weight of the rear of the van is on the bags that are been canter levered, seems a massive weak point, I need a really strong rear set up, I already have some big airlift dominator 2600 bags I'll be using, due to the weight that will be in the back, I'll have 1.2 tonn plus in the back full of audio equipment, may have to end up making my own out of some real thick box section,Russw wrote: I have just had my van aired on the intermotive rear kit and had to be modified to suit a maxi. A few parts had to be altered/tweaked
How does it drive handling wise been a trailing arm set up with the Watts linkage??
I'll sort some pics out.
Looks absolutely stunning. Is there any issue with water fitting the compressor under the van? I.e puddles and heavy rain?
Interested in seeing more on this
