Hi all!
Was looking for any advice on wing mirror covers for the install however found none, so for anyone who wants to know, it’s really simple to figure out but if this helps then great!! No need to take off door cards like I’ve heard else where.
1) unscrew the two screws underneath the mirror and take the underside piece out.
2) pull the mirror frame out, quite a few poppers on the inside by the window so be careful not to snap these.
3) use a screwdriver and flick the rest of the cover up around the inside, the rest you can pull out with your hands. Luckily you won’t have to remove the mirror glass.
Then it’s literally the reverse to get them back on. Here are a few pics from today’s install..
Wing mirror covers
