Bluetooth Module
- Frax
Bluetooth Module
My Caddy Maxi has Bluetooth connectivity for my phone, but I am unable to connect it so I can use Spotify for music.
I’ve been told I need a Bluetooth module for my RCD510. Anybody know what I need and how to connect it up?
Help much appreciated.
Re: Bluetooth Module
So, even though you have Bluetooth, someone has advised you need Bluetooth??
I don't get it!
Do you have access to VCDS to at lease learn which exact Bluetooth module you already have?
I don't get it!
- Frax
That does sound stupid now you mention it, haha. I’m clueless when it comes to this stuff.
All I know is, that my phone connects so I can make and receive calls, but nothing in the way of music streaming.
I’ve just come into the Caddy world and don’t know anyone with VCDS. I’m in Reading, Berkshire if that helps.
Matt.
- Afield23
Is this the same problem with parrot kits working with phone Bluetooth but not music? If so I bought a cheap aux adapter that now accepts my Spotify.
- Frax
I’ve got and aux, I just want the convenience of connecting wirelessly.
My old transporter once phone connected play something on your phone them hit media button on radio and it played music, couldn't change song though without doing it on phone...
- Afield23
My adapter is wireless and plugs into the auxFrax wrote: I’ve got and aux, I just want the convenience of connecting wirelessly.
https://www.amazon.co.uk/KitSound-MyJac ... B018G9FP4W
- Frax
So there is no way of wirelessly doing it apart from a wireless aux thingy? I’d like track info and the ability to skip tracks on the head unit.
Anyone with a RCD510 shed any light, or is it a non starter?
It depends on the Bluetooth module whether you can stream music or not.
It depends on the SW level of the RCD510 whether you can see track info and skip forward and back.
Without information on both, it is impossible to say.
- Frax
Ok, I’ve done a bit of research and I can’t decide if it’s the module that needs updating to the 9w7 or the RCD firmware.
Will it tell me the firmware if I hold down the setup button?
- Frax
Ok, I managed to get some pics which might help.
So the display shows that I have the option of BT but I am unable to press it.
This I'm guessing is the firmware.
I could be way of here... have you tried pressing play on your phone then trying to select it. I have to do this on my head unit that is a lesser model than yours. I cant select the Bluetooth audio until something is playing .
- Frax
Yeah, I read that somewhere, tried it and still didn’t work.
Sorry worth a go !Does the music play from your phone when connected to Bluetooth or is it silent like it’s connected else where ?
- Frax
AUX is fine, just plug that in and away we go. Bluetooth is fine on the RCD for calls, phonebook etc. I can use hands free via the mic in the interior light unit. If I disconnect from aux and try and play music it just comes out of the speakers on the phone.
I had a look under the seats for the bluetooth module, but it isn't there. From what I've seen, it's usually in a foam surround attached to the floor with velcro.
Went to the VW dealer in Reading today, explained the situation, and they were just as clueless as me tbh. He said he would look into it, but I'm not holding my breath.
