Opinions on 18’s vs 19’s
Re: Opinions on 18’s vs 19’s
Iv always liked them motorsport style wheels... hmmmm
The wife is worried, she found me sat looking at my wheels in the garageRicksy1121 wrote:Iv always liked them motorsport style wheels... hmmmm
- torque777
Vw motorsport wheels are my favourite wheel... If I dropped on a set one day I might be tempted to go back to 19"
Zito 935 Alloy Wheels Set Of 4 19x8.5 Inch ET45 5x112 PCD 73.1mm Centre Bore Gloss Black
Apart from spigot rings the above wheels should fit with 225/35/19 tyres with a 97 load rating ?
torque777 wrote: ↑Sun Nov 19, 2017 11:33 am I found on a maxi you don't need centralising plates like you do on a swb, I tried vmaxx for about 6 months and I didn't really like the ride, it was comfortable but under damped especially at the rear, I went for spax rsx front coilovers and gaz rear dampers with darkside rear lowering kit, both the spax and gaz have adjustable rebound and I found this perfect for setting the ride to how I wanted it, I went further and fitted Powerflex complete rear kit, and will be doing the front next year, when you lower you will find the rear wheels move more side to side due to having longer rear shackles, so you can get a spacer block kit from fb that helps limit that, the Powerflex bushes really help also but that's a mod that can be done later on when funds allow
I've added a photo of mine to show the height I run on a daily basis
What sort of drop are you at, it looks a good at that height
- torque777
About - 60mm I'm guessing
- gee101a
Ricksy,
I fitted a vmaxx kit to my maxi and to be honest wouldn’t recommend it. I run 19’s and and it hasn’t been straight forward but I’m nearly there. The vmaxx cost 400 quid, wasn’t low enough and put the rear wheels well out of centre. Have a look at my thread “face-lift maxi axle relocation and lowering” I’ve just bought a set of Gaz adjustable rear shocks at a further 150 quid, not fitted them yet but hopefully all will be good. Also needed centralising plates which would have been a further cost if I hadn’t modified the vmaxx ones. Fronts were fine by the way.
I think my point is think carefully before you decide on what suspension you buy. Not necessarily better to buy the complete kit like I did, compared to sourcing all the components individually.
Good luck and 19’s is the way to go
Gee
Gee
Hi if that thread is in a locked section I won’t be able to read it just yet, Iv requested my access is upgraded now so soon hopefully, I think I will shell out the extra money for the dark side kit with either the gaz or Bilstein Do you think I will need centralisation plates with that kit as well ?
My next thing is tyres, finding 35 profile load rated tyres is challenging, do you know what the lowest load rating should be. I can work it out later I just keep forgetting to check the axel weight sticker lol.
- gee101a
Screenshot my post for you, hopefully you will get access soon, lot of good information on here.
Gee
Gee
- gee101a
[Administration Edit:
Posting screenshots of a restricted area of the forum is not acceptable behaviour]
- gee101a
Thanks for that, I will just avoid that kit I think.
- RKDesigns
Normal v-Maxx is shit... just pay a bit more ... the xxtreme version from v-Maxx is good under a Caddy and the struts are nessesary in front.
Struggling to find 19’ with the correct load rating for the back of a caddy maxi, do you guys make sure the load is correct ? Needs a load rate of 93 or more for the rear I worked out. Finding that in a 225 or 235 35 isn’t going well. Might have to wuss out and get 18”s
