Hi all,
New member here and I was just wondering will the rear leaf spring adjusters out of a 2007 fit my 2011 one?
If so are they hard to fit?
Tia
2007 and 2011 rear leaf spring adjusters
Re: 2007 and 2011 rear leaf spring adjusters
Apart from the facelift in 2011 and the shift to the 1.6 and 2.0 CR engines the Caddy was virtually unchanged between 2004 and 2015 so I'm assuming they will fit
- Maxi4life
Depends on the leaf springs if your talking shackles as well. All to do with those locating nubs on the springs because if they are cast on then you won't be able to flip them around but you won't find out until you drop the rear axle.
Thanks all much appreciated
