New injectors from euro car parts?
Does anyone know if the injectors from euro car parts are the same as the ones from tps etc? Want to get a spare for in the caddy incase one goes on a long run out... thanks
Insta : Limbo118118
Re: New injectors from euro car parts?
Someone mentioned this recently, apparently they have the Siemens ones but also do a Lucas version much cheaper
- Barbel330
Check that they're not refurbed ones. I'm sure when I looked a while ago they were but may be different now. You don't want refurbed ones.
Instagram: @y_5cuf
Yeh they have 2 listed.
- VDO siemen
- lucas
- VDO siemen
- lucas
Insta : Limbo118118
Cheaper at PF Jones on line , £216 last time I looked , brand new .
Also, an injector in the glove box next to your spare brake light bulb is a novel idea, you might need a VCDS in there too
Just bought my 90 pence plus vat stretch bolt from tps today. Might get an injector to go with it!
2011 1.6 102ps ex BG
225/40/18 ps3 Santiago wheels
Surely a refurb one is okay, its the electrical part that fails which will be replaced on a refurb..?
- brownmaximan
The injector is a sealed item, so the coil can’t be replaced. Any used or refurb is likely to fail the same way, so new is the only sensible solution.Gaz-M wrote:Surely a refurb one is okay, its the electrical part that fails which will be replaced on a refurb..?
+1 to that ^^^ on the "refurbed" ones.....
that place in manchester seems to be the best price for new injectors!
Insta : Limbo118118
- lavinl30
Limbo118118 wrote:+1 to that ^^^ on the "refurbed" ones.....
Where’s the place in Manchester bud?
