Be a while since messing with motos due to new job so a bit rusty on diagnosis of problems
washed the van outside only
and after that ended up with dash stopping working and check oil pressure stop engine and abs light on
heres the vagcom read out below
dont suppose anyone nos a list of sensors on b voltage line after some reading found out theres 2 5volt lines A and B
any help would be much appreciated as i really dont want to spending ages checking loads on stuff in this disgusting weather
it aint no fun especially when u working out in it most days
main issues is the sensor reference voltage b problem causing all the other faults
as none of then actually clear
list of symptoms
engine starts
speddo does not rev
stop check oil pressure stop engine
abs light on
no engine management light
engine idels abit lumpy
whn i get a chance im going to check oil pressure sensor probably just replace it for ease
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 AQ HW: 028 101 239 0
Component: R4 1,9l EDC G000SG 7529
Revision: --H01--- Serial number: XXXXXXXXXXXXXX
Coding: 0000031
Shop #: WSC 35110 377 00155
VCID: 6ED39ED379F3393673-803A
1 Fault Found:
001619 - Sensor Reference Voltage B
P0653 - 000 - Too High
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 296915 km
Time Indication: 0
Date: 2000.00.00
Time: 17:09:22
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00000000
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 35110 377 00162
VCID: 3F8D13976E1980BEA8-806A
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005450621
Coding: 01804F030000000001000000000000000009F7075C00000C000000000000
VCID: 71E985AF68CD26CE6E-8024
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 150108 021 0501
Coding: 00038805
Shop #: WSC 35110
1 Fault Found:
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 296915 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5KD 919 475 HW: 5KD 919 475
Component: PARKHILFE 4K H07 0001
Revision: -------- Serial number: 05211318000241
Coding: 100001
VCID: 071DCB77B649087ED0-8052
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD0HADBH
Coding: 0012345
VCID: 7DF1A99F249552AEFA-8028
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000531
Shop #: WSC 01342 020 00200
VCID: 7AFBA28335BB6596DF-802E
Subsystem 1 - Part No: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4ÿ 0021
Coding: 00000226
Shop #: WSC 00000
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1T0 920 974 B HW: 1T0 920 974 B
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H03NI1IQ
Coding: 0016401
Shop #: WSC 70305 067 57207
VCID: 366376B3412341F67B-8062
1 Fault Found:
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 296915 km
Time Indication: 0
Date: 2000.00.00
Time: 17:09:53
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 290108F1000146
Coding: 89A01F020006027403
VCID: 306F40ABA3476FC621-8064
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 2416
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1206
Coding: 0000624
Shop #: WSC 35110 377 08192
VCID: 387F788B4B37B78669-806C
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 998B0C087F2D8405481A030010C0
Shop #: WSC 00581 210 71811
VCID: 000FD06B53673F4691-8054
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000624
VCID: 39797D8F703DAE8E96-806C
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3H3335613
Coding: 0B00040001
Shop #: WSC 01324 785 00200
VCID: 65C1E1FF6C05FA6E02-8030
1 Fault Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 296915 km
Time Indication: 0
Date: 2000.00.00
Time: 17:11:41
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A08765386
Coding: 410020
Shop #: WSC 00078 790 00186
VCID: 2A5B52C3459B1516EF-807E
1 Fault Found:
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 296915 km
Time Indication: 0
End-------------------------(Elapsed Time: 01:26)--------------------------
A bit of vagcom and technical help please
- paul4314
- paul4314
Re: A bit of vagcom and technical help please
Found this problem turns out the egr valves faulty shorting out the sensor circuit
