Hi,
I have an 08 1.9tdi caddy, both the heated seats have stopped working have checked the fuses they are fine.
I guess its just a coincidence but i had to put a sleeve over the windscreen washer tube where into goes into the hood. as it was broken, the same day the heated seats stopped working, not sure if i could have disturbed some wires there.
Look forward to any tips on where to look or a wiring diagram.
Regards,
Bob
Heated seats suddenly not working
Re: Heated seats suddenly not working
You should have heated seat module fitted under the passenger seat. That gets power from fuse 48 30A fuse. Top row of big fuses in fusebox.
Best is to scan the car with vcds or similar to see if there's fault stored if fuse is ok
