Side door catching wheel
How do you solve the problem of side door catching wheels
Re: Side door catching wheel
Smaller wheels maybe?
- PaulC61
Big hammer and beat the inside of the door maybe?
- Beaker2135
- RKDesigns
I have done that Some years ago, but it worked out Well to fit 10J rear wheels lolPaulC61 wrote:Big hammer and beat the inside of the door maybe?
Someone on her said that someone makes wedges on her. Un sure of how it works?
Someone on here cut the bottom of the inner door panel off and narrowed it and welded it back back on but I can't remember who, it was on a build thread. But narrower wheels seems to be the sensible option
- RKDesigns
Hef355 his Caddy has it.CaddyShack2k wrote:Someone on here cut the bottom of the inner door panel off and narrowed it and welded it back back on but I can't remember who, it was on a build thread. But narrower wheels seems to be the sensible option
just cut the van in half front to back. weld in strip of metal and voila! now your van is wide enough for the wheels you have chosen. doing it this way means you can make the van as wide as you want it. do it big and get some wheels off a tractor. guaranteed you will have a van like no other!! You're welcone
2013 ex British Gas Caddy Maxi Camper/Work Van
You can get a wedge for the vw T4 maybe you can get one for the caddy too? or mod the T4 one?
