Remapping
- Barbel330
- lord-dudester
Re: Remapping
I pad 400 for what described as a custom map
Your off the shelf ones 300 ish
Custom will push your engine a bit harder than the mainstream guys
Re: Remapping
if you have the 1.6 I know revo do a remap for 400. if you had an earlier 1.9 It is cheaper. I have heard it is well worth doing. apparently makes the 1.6 a lot nicer to drive
2013 ex British Gas Caddy Maxi Camper/Work Van
- carper69
Re: Remapping
Cheers guys
- IANDIRL
Re: Remapping
Had mine remapped here in Sportchip.ie located in Blachardstown Co.Dublin Ireland.
Full custom map took about 2 hours.
Cost: €250
Resulting in nearly double the power very happy overall way more confidence driving can actually overtake (only if safe to do so).
Consumption is down a small bit although I have upgraded the wheels from standard to 17" and carrying a small bit more weigh in the rear.
Cost: €250
Re: Remapping
Any recommendations in the South of England for chippin?
Re: Remapping
Was going to ask the same for Berkshire area
Re: Remapping
Berks, Bucks or Herts would do
Re: Remapping
Any recommendations in Cheshire???
Re: Remapping
If you contact Amy Hill at support@black-code.co.uk, they have people nation wide.
Re: Remapping
Thanks for that, I will make some enquiries.
Re: Remapping
Anyone recommend anyone near Glasgow ?
Re: Remapping
Performance Tek in Dalmarnock 01416119601.
Re: Remapping
Did they say what it started out at?IANDIRL wrote: ↑Wed Jan 31, 2018 12:44 pm Had mine remapped here in Sportchip.ie located in Blachardstown Co.Dublin Ireland.
Cost: €250
