Hi,
I have a small dent in the lower rear panel of my left side rear door. I want to push this out from inside. I've removed the inside cover panel but now i want to remove the door lock mechanism to get to the metal panel behind.
Please could someone explain the correct way to remove this lock mechanism? I can see 4 largish Torx head bolts but.....???
Thanks,
Matt
Rear Door Dent Removal
Re: Rear Door Dent Removal
It might be quicker to get a PDR guy to remove the dent. You will not have to remove anything then.
