Low beam not workin on drivers side
Can someone help me out i have a 2011 caddy. Mu lights r h4. On the drivers side the low beam doesnt work but the high does anyone whats going on with it
Re: Low beam not workin on drivers side
Have you checked the bulb and fuse? Was there a dash warning that the lamp is out?
The H4 is a dual filament bulb. Sounds like your low beam filament has gone, in which case, you should have an amber light on your dashboard.
Bulb and fuse is fine
Swap the bulbs around just to be double sure mate, sometimes it’s a bit difficult to see the filament......or is that my dodgy eyes?
