brooneye wrote:Find out the modules codes first and then try to do a little research to see if they are compatible with the mirrors.
If you then draw a blank someone on here will always try to help you. The search button on here and google will always be your friend in times like this
brooneye wrote:Simple answer no. They need the base plate extending (this needs plastic welding), holes don’t match up for locating bolts do you need to drill new ones.
I was fortunate that I bought the mirrors along with the door cards and the windows from the same touran so all the modules were there. By doing this I knew everything would work but you may need them coding.
What type of windows do you have? Check to see if there is a vacant slot that will accept the mirror plug on your module and that they are compatible with touran mirrors.
It is worth all the time and effort as in my opinion they do look better and I had no problems going from the larger caddy ones to these
Hi brooneye I took my door card off today and took a couple of pics of the passenger side door module
Do you have to quote the previous post in EVERY reply?
Please look back through this thread and see how messy it is with all the quotes.
If you are replying in a thread and a quote is not necessary, please use the reply option instead.
If you feel all these quotes are necessary, please explain why.
Doc wrote:Do you have to quote the previous post in EVERY reply?
I can only comment on what I have used and done. Again as I mentioned earlier do some research on the mirrors ie year, what functions they do and what plug is on them? Once you have this info have a search on here to see what other people are using
brooneye wrote:I think you may of answered your own question.
