Touran door mirrors
- Trevor789
Touran door mirrors
Hi all has anyone changed the door mirrors to touran ones
- Afield23
Re: Touran door mirrors
Lots of people have yes.
- milosbgd011
Found on ebay,think that fit
- milosbgd011
I’m looking to upgrade my mirrors but can’t decide, I do quite like the originals but just a little old and outdated, plus they are standard manual so that’s got to change.
Touran dashboard, Adjustable armrest, 25th Edition seatbelts, 30th Edition leather/tartan seats, sunglasses holder, Touran carpets and floor mats, Facelift highline cluster, RCD330, reverse camera, Climatic, Mk5 leather MFSW, Cruise control, LED Projector headlights, 16” wheels, Leather handbrake / chrome button, Mk7 gearknob, Auto headlights & Fully carpeted, sound deadened and insulated!
- btaylor2k
My mates breaking a touran so I'm gonna raid it for interior and mirrors, they look so much cleaner
Kerbside Kustoms
I like my old originals, they give excellent rear vision which is great when you consider that the interior rear view mirror is as much good as an ash tray on a motor bike
- LeeH
Touran door mirrors
I presume these need a little butchering to fit?
- Trevor789
For what I’ve read there’s slot of converting to be done plus wiring
- Trevor789
Is it a easy conversion?Afield23 wrote:Lots of people have yes.
- D green
I did mine on my 06 you need to plastic weld part of the base plate from you old mirrors fill sand and paint then new holes drilled into the door then I plugged them directly into the door control module salvaged from the same car to upgrade to electric widows at the same time fare bit of work but definitely worth the effort
So you have to buy a decent plastic welding iron, min 200w so it will weld the abs plastic, a good one with rods and stainless steel mesh is about £160. Like I say, I like my mirrorsD green wrote: ↑Sat Mar 03, 2018 5:43 pm I did mine on my 06 you need to plastic weld part of the base plate from you old mirrors fill sand and paint then new holes drilled into the door then I plugged them directly into the door control module salvaged from the same car to upgrade to electric widows at the same time fare bit of work but definitely worth the effort
- Afield23
It's definitely not plug and play, and not something i would attempt. Good luck if you do, I know I would balls it up myself.Trevor789 wrote: Is it a easy conversion?
- Trevor789
I’d buy some already converted if I could find anyAfield23 wrote:It's definitely not plug and play, and not something i would attempt. Good luck if you do, I know I would balls it up myself.
Totally agree with you CaddyShack2k.CaddyShack2k wrote: ↑Sat Mar 03, 2018 7:11 am I like my old originals, they give excellent rear vision which is great when you consider that the interior rear view mirror is as much good as an ash tray on a motor bike
