Carista obd plug
Martin451
Carista obd plug
Post by Martin451 » Tue Mar 06, 2018 9:22 pm
Just got a Carista obd plug
Been messing with the settings on my van
Made up with it,tuned off the cornering lights,changed the indicator’s to flash 5 times not 3 and changed the coming home and leaving home lights from the dip beam to the fog lights,also activated the rear doors to auto lock when I drive off
Thinking of going back outside to see what else I can mess with 🤪🤪🤪
mark1a
Re: Carista obd plug
Post by mark1a » Tue Mar 06, 2018 10:28 pm
Mine arrived at the weekend, I’m impressed too.
There’s a few things apparently supported but have not worked, so I’m going to contact them to check.
List of things I did in the first 10 minutes at the bottom of page 2 of my build thread (so as not to duplicate content here).
2017 Blackberry Maxi Life 150TDI OEM+
Brescia Clubsport 18” | OE Xenons | Limo tints | Vanstyle side bars | Climair wind deflectors
H&R / Darkside lowering | TRC front splitter
Android HU | 4G WiFi
Gaunt
Post by Gaunt » Tue Mar 06, 2018 10:46 pm
I see you have caddy 4... I bought a Carista obd for mine and says it’s not supported with my model? Is there different ones to get?
mark1a
Post by mark1a » Tue Mar 06, 2018 11:05 pm
No, same one. The mk3/4 didn’t occur to me as it lists on the website as 2004-current and they also support newer VAG models so ordered it.
mark1a
Post by mark1a » Tue Mar 06, 2018 11:07 pm
It all seems OK apart from what I mentioned and it reports 2 errors with instruments and BT which I think are down to the fact that the OEM head unit is missing.
mark1a
Post by mark1a » Wed Mar 07, 2018 6:23 pm
I've got a support ticket open with Carista for some queries, first thing they've come back with is:
Thank you for using Carista. Yes, we do support your vehicle for customizations, advanced diagnostics, and service.
mark1a
Post by mark1a » Thu Mar 08, 2018 8:15 pm
Update for Carista dropped this morning in App Store, some new customisations available, including needle sweep, which I’ve enabled of course.
Kreutz
Engine size/power: 2.0 CNG (107bhp)
Post by Kreutz » Fri Mar 09, 2018 12:51 am
Haha, ordered it immediately now :lol:
Martin451
Post by Martin451 » Fri Mar 09, 2018 8:46 pm
More messing with the settings
Just wanted to know if anyone knows what difference the head light voltage does
Think mine is set to 13 volts
Paul9616
Post by Paul9616 » Fri Mar 09, 2018 8:51 pm
Martin451 Do you have any screenshots or a list of what you can do with this? I did see some pictures on the T6 forum but the quality was that poor i couldn't see what you could do.
I even downloaded the app last night but you need the reader to look at what you can do?
Black 2011 C20 1.6 tdi 100 bhp / remapped to 140ps, 18" 3sdm 0.01 alloys, Coilovers, Lower GTI splitter, Touran 5 seat conversion, Mk6 golf GTI red stitch flat bottom steering wheel, Touran centre console and armrest, TRC splitter Mk6 GTI.
Golfchick
Post by Golfchick » Fri Mar 09, 2018 8:58 pm
I've got a carista dongle so tempted to pay up to check out what it can do/enable some things. One thing I enabled on the skoda was the high pitched beep when you locked/unlocked the car. Can this be done on the van does anybody know? It's one of the few things I miss the most!
TonyC
Post by TonyC » Fri Mar 09, 2018 9:24 pm
Look on their site, select the vehicle, click customisations and there is a sample list of what can be done there
mark1a
Post by mark1a » Fri Mar 09, 2018 10:00 pm
Martin451 wrote:More messing with the settings
Mine was set to 13v too, have factory xenons so left well alone as I’m happy with them.
mark1a
Post by mark1a » Fri Mar 09, 2018 10:04 pm
Golfchick wrote:I've got a carista dongle so tempted to pay up to check out what it can do/enable some things. One thing I enabled on the skoda was the high pitched beep when you locked/unlocked the car. Can this be done on the van does anybody know? It's one of the few things I miss the most!
I’ve enabled beep on lock & unlock on mine. It only works if you have factory alarm system, which I have. However the double beep on unlock works fine, the single beep on lock doesn’t. Have a support ticket open with them.
This is what needs to be set:
Allow configuring beep when locking/unlocking - YES
Beep when locking with remote - YES
Beep when unlocking with remote - YES
Paul9616
Post by Paul9616 » Fri Mar 09, 2018 10:31 pm
Thanks I'll give that a look on Monday as it doesn't seem to want to work on the bloody iPad
