Page 2 of 3
Re: Carista obd plug
Posted: Sat Mar 10, 2018 8:30 am
by TonyC
Paul9616 wrote: Fri Mar 09, 2018 10:31 pm Thanks I'll give that a look on Monday as it doesn't seem to want to work on the bloody iPad
Doors / Windows / Remote
Auto-lock doors when moving
Yes / No
Auto-unlock doors when key is taken out of ignition
Yes / No
Auto-lock trunk when moving
Yes / No
Unlock trunk when doors are unlocked
Yes / No
Blink turn signals when locking/unlocking with remote
Yes / No
Allow configuring beep when locking/unlocking
Yes / No
Beep when locking with remote
Yes / No
Beep when unlocking with remote
Yes / No
Unlock doors via remote
Driver's door on 1st press, all on 2nd / All doors on 1st press
Enable settings for opening/closing windows and sunroof
Yes / No
Open/close windows and sunroof via long-press on remote
Yes / No
Open only driver's window via long-press on remote
Yes / No
Open sunroof via long-press on remote
Yes / No
Close sunroof via long-press on remote
Yes / No
Sunroof action when opening via remote
Slide / Tilt
Open/close windows and sunroof by holding key in door lock
Yes / No
Blink turn signals when done closing windows via remote
Yes / No
Enable remote control buttons when ignition is on
Yes / No
Instruments / Display / Dings
Instrument cluster region (affects ext. lights too)
Germany / Europe/other / USA / Canada / Great Britain / Japan / Saudi Arabia / Australia
Multi-Function Display
Enabled / Disabled
Seat belt warning
Enabled / Disabled
Lane-change turn signal auto-flasher
Enabled / Disabled
Lane-change turn signal auto-flasher count
1 flash / 2 flashes / 3 flashes / 4 flashes / 5 flashes
Push-to-talk (PTT) button function
Push-to-talk / Mute
Park distance visualization (if equipped)
Enabled / Disabled
Rear parking sensor beep volume
1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / Max
Rear parking sensor beep tone
Type 1 / Type 2 / Type 3 / Type 4 / Type 5 / Type 6 / Type 7 / Type 8 / Type 9
Rear parking sensor beep volume when convertible top is open
Lights
Allow configuring daytime running lights via dash display
Yes / No
Use designated DRL bulbs as daytime running lights
Yes / No
Use low beams as daytime running lights
Yes / No
Use fog lights as daytime running lights
Yes / No
Turn off daytime running lights ("wink") when turn signal is on
Yes / No
Turn off daytime running lights when parking brake is on
Yes / No
Daytime running lights (DRL) brightness
0-100 %
Headlight brightness control
Disabled (direct battery voltage) / 12.3 volts / 12.4 volts / 12.5 volts / 12.6 volts / 12.7 volts / 12.8 volts / 12.9 volts / 13 volts / 13.1 volts / 13.2 volts / 13.3 volts / 13.4 volts / 13.5 volts / 13.6 volts / Default
Taillight brightness control
Coming-home lights
Enabled / Disabled
Leaving-home lights (req. auto headlights)
Enabled / Disabled
Coming-home lights mode
Manual: flash high beams to activate / Automatic: when it's dark (req. auto headlights)
Coming/leaving-home lights use…
Low beams / Fog lights
Turn off all lights when headlights are left on and ignition is switched off
Yes / No
Turn off front fog lights when high beams are on
Yes / No
Turn off rear fog lights when high beams are on
Yes / No
Cornering lights (using fog lights)
Enabled / Disabled
Flash brake lights in emergency stopping
Yes / No
Flash hazard lights in emergency stopping
Yes / No
Brake lights work even when ignition is off
Yes / No
Other
Power steering weight
Lightest / Lighter / Light / Normal / Heavy / Heavier / Heaviest
Hill hold assist release
At low RPM / Normal / At high RPM
TSC (Torque Steering Compensation)
Enabled / Disabled
Lower passenger-side mirror when in reverse gear (req. memory seats)
Yes / No
Additional 'tear' wipe after rear window washer use
Yes / No
Auto-enable rear wiper when front wipers on and reverse gear engaged
Yes / No
Auto-enable rear wiper when front wipers on (interval) and reverse gear engaged
Yes / No
Auto-enable rear wiper when front wipers on (continuous) and reverse gear engaged
Yes / No
Posted: Sat Mar 10, 2018 1:32 pm
by Golfchick
How do I know if the van has factory alarm system? Last time I used Carista I think it was £10ish for 7 days use.
Posted: Sun Mar 11, 2018 8:22 pm
by mark1a
Golfchick wrote:How do I know if the van has factory alarm system? Last time I used Carista I think it was £10ish for 7 days use.
I’m not sure, I only knew mine did because it was listed under standard equipment when I bought it.
Posted: Fri Mar 16, 2018 3:02 pm
by feherb
Does the program work with other adapters? Or should I buy a Carista adapter? Does have anybody experience?
Posted: Fri Mar 16, 2018 3:29 pm
by mark1a
The app works with some other adapters listed on their website, but if you use the official one at £15.99 you get a 30 day trial with all features unlocked.
This was enough to get all the adaptations I wanted and clear out some fault codes.
Posted: Fri Mar 16, 2018 6:30 pm
by feherb
Than you!
I have already an adapter, i will cheek it.
Posted: Sun Aug 19, 2018 8:34 am
by Bungle
Will this allow me to clear the fail codes thrown up by the LED repeaters, LED DRL and the LED number plate lights?
Posted: Sun Aug 19, 2018 5:44 pm
by mark1a
It will almost certainly allow you to clear the fault codes, however it won't stop them from coming back again. For that you would need VCDS.
Posted: Sun Aug 19, 2018 8:35 pm
by totty79
I think Carista might be able to code led bulbs, email their support to confirm it.
OBDeleven Pro can definitely do it so VCDS is not the only option.
Posted: Sun Aug 19, 2018 9:07 pm
by Bungle
Thank you. But from what I can understand I can’t use OBDeleven with iOS.... :-(
Posted: Sun Aug 19, 2018 10:59 pm
by Bungle
Update - OBDeleven and acer tablet ordered......
Posted: Mon Aug 20, 2018 12:09 am
by Sparky6911
OBDeleven is good for the simple stuff, struggle to get my head around the long coding part at the moment though as it's not a self explanatory as VCDS
Sent from my Moto G (5) Plus using Tapatalk
Posted: Sat Nov 24, 2018 8:02 pm
by caddychris2002
Did you manage to code the LED lights out using OBDeleven if so how i still haven't got my head round it
Posted: Wed Jan 09, 2019 8:50 pm
by ViralEye
Just dragging up a thread from a couple of months ago as my obdeleven arrived today and I'm scared I'm going to do something and brick the van
Any guides or anything add there is naff all online!
Posted: Thu Jan 10, 2019 9:11 am
by totty79
Pro version or standard?
I've got the pro version and you can pretty much use VCDS guides. I think the standard only has the apps and they tend to be self explanatory.
