Caddy 1.6 DPF and egr delete/blank
Hi everyone,
I’ve had my caddy just over 12 months now and want to remove the dpf or cut out the honeycomb and blank the egr. Now I can do the work myself in terms of the dpf and removing or blanking the egr. The only issue I have is that I’m not sure whether to do anything with the egr itself or leave it alone and only do the dpf and remap.
So my questions are
Do I just blank it?
Will it bring up any warnings that I will need to get removed?
Is it worth doing?
If I do the dpf and remap will I gain anything from blanking the egr?
Has anyone else done it?
Cieran
So my questions are
Do I just blank it?
Is it worth doing?
Cieran
- Caddyluv
Re: Caddy 1.6 DPF and egr delete/blank
Can’t answer your question but thought I would say I’m looking to keep the dpf and remove the egr when I do the remap next week I believe it can be programmed out so no need to mechanically remove it. Not 100% sure yet doing a little more research. It is a hot heated topic on here.
Loving the van. love the wheels.
- Cabbs
Hi Mate,CieranL555 wrote:Hi everyone,
So my questions are
Do I just blank it?
Is it worth doing?
Cieran
Was you aware of the new MOT criteria’s coming out in April/May this year. I was only talking to my MOT tester today regarding this (He’s my mate) and they are to start looking for seems welded or broken/cut on the dpf and have to fail anything that looks to have been tampered with. He also advised that on roadside checks/census they will be looking for this and will impound your vehicle should it not pass the pollution check. Again the same with coil overs and shackle kits. Have a look on the ministry of Transport website mate. He says the new rulings are all there. Just a heads up.
Hi mate, yes aware of the new legislation on dpf but have got it sorted in regards to mot, as for coil overs and shackle kits, there isn’t anything regarding that if they have been fitted correctly with correct bump stops etcCabbs wrote: Hi Mate,
Thank you for you concerns though
- DING-DONG
How they going to test pollution check when the vehicle does not rev past 2k when stationary ?
- RKDesigns
Delete nothing just go for custom remapping which solved trouble with those Parts. These are not for nothing on the engine. With the factory standard 1.6 TDI they are a common problem, however custom remapping works the best for those Parts to work properly. Never had problems after remapping. VW doesn’t like it, it doesn’t need any repairs
Auschwitz, Dachau, Zobibor, Bierkenau, Belsen, Wolfsburg, which ones the odd one out? None of them
- Barbel330
You should sell your van as a protest and get a push bike.
Instagram: @y_5cuf
I like my van and a pushbike sounds too much like graft
Can some one explian in idiot language y your doing both these mods please ? keep seeing this everywhere but dont really know y its being done and what the benefits are
- DING-DONG
Codling893 wrote:Can some one explian in idiot language y your doing both these mods please ?
Wow so much aggression !
Haha sorry mate just read it back, came across completely the wrong way hahahDING-DONG wrote:
