injector failure
- Paul9616
Re: injector failure
Wow
How to escalate a reasonable answer.... Trump esc
Black 2011 C20 1.6 tdi 100 bhp / remapped to 140ps, 18" 3sdm 0.01 alloys, Coilovers, Lower GTI splitter, Touran 5 seat conversion, Mk6 golf GTI red stitch flat bottom steering wheel, Touran centre console and armrest, TRC splitter Mk6 GTI.
injector failure
I was under the impression that from 2013 on, the injectors VW were fitting were of a better quality.
If Daveys injector has gone on a 14 plate at 47k that suggests there is still an issue. Does this mean that anyone who has had newer ‘S’ injectors is likely to have more issues?
At 4-500 quid a go, I hope not!
- Geardy1986
My brother’s is a 14 plate, but still has the ‘B’ injectors... so don’t think it’s as clear cut as everything post 2013 is ok
- hatman
It could be possible that it was built prior to 2013, held in stock for over 12 months & regisitered in 2014
2020Viper Green High Line, 150ps 6sp DSG Xenons, mfsw, reverse camera, winter pack, folding mirrors, 18” Gloss black Bola B1”s Gloss Black roof/grills
Very true @geardy and hatman
It is also possible that it is a faulty injector, maybe a very small percentage of the thousands made, even though it might be the revised version.
It's also possible it has had a hard life, bad fuel, poor servicing, maybe been swapped out by a unscrupulous mechanic who wanted a revised injector for himself. Who knows.
That’s very true also Doc.
Mine is a 64 plate, first registered in Sept 2014.
Have just had an injector replaced at the local stealership.
£879 quoted and finally paid £559 with a 36% goodwill payment by the dealer, as VW refused to pay anything.
The reason VW wouldn't pay, is because I had refused the emissions fix, when I registered the vehicle in my name.
Unfortunately I don't know how to check which injectors are in my engine.
Could you point me in the direction of how to identify them?
Mine went at 22k last week 12 plate unfortunately it seems the normdavey77 wrote:Got a 14 plate 1.6 diesel (75) caddy, injector failure and only done 47k, is this normal ?
Brock, the part number is on top of the injector. If it ends with a B, it is the old type that are prone to failure. If it ends with an S, it is the newer, more reliable type.
Thanks for the info swan fiend, I'll check the other 3 injectors some time.
I had the VW emissions fix done when the dealer fitted the new injector.
It seemed the only way I might avoid three more expensive injector fittings, due to the 2year/100000 mile warranty they say I now have.
My van seems to be running much more smoothly now and I haven't noticed an increase in fuel usage.
Fingers crossed for the next month or two!
injector failure
No problem mate, happy to help if I can
Hopefully you’ll have no more issues. then you can spend your hard earned on mods, not fixes!!
I must admit, the injector issues haven’t filled me with confidence doing long journeys. I’m debating weather to buy a spare injector, I’m going to look into weather the AA could fit and code one roadside.
I ended up being recovered by the RAC last week and the bloke was telling me that the AA have allocated service vans that carry injectors and fit/code injectors at the roadside. At a cost obv.the swan fiend wrote:No problem mate, happy to help if I can
Yes, I heard that too
