Hi,
My passengers window opens but will not close with the switch on the drivers side but works ok from the passenger side.
I suspect the switch & was wondering if anyone has used the cheap ones available on eBay or is it best to go OE?
Window switches
Re: Window switches
Same problem here ,was just looking on eBay ,also any tips to remove without damaging door cards
Re: Window switches
I have a light out on my drivers side passengers switch. How do I fix this?
Re: Window switches
I replaced the window switches on the driver side, with the switches from eBay and have had no issues with them.
I did the head light rotary switch at the same time,both took minutes to fit.
Youtube has videos on these subjects which is always worth a watch before under taking the relacement.
Re: Window switches
Just bought a set today, I thought I'd give it a try for the price the only reason I'm changing is that the OEMs ones are starting to look tatty.
