Not going down the prosport route as had issues with those and they are bouncy.
Now looking at either Vmaxx or AP coilovers.... anyone had any issues with either?
Or know what the ride like on either
Any help is appreciated
Vmaxx or AP coilovers?
- btaylor2k
Kerbside Kustoms
- RKDesigns
Re: Vmaxx or AP coilovers?
V-Maxx just take the XXtreme kit and its adjustable 20 stands on the dampers. Drives well even on 20” if you want a set just let me know.
- btaylor2k
Very interested in a set mate, not sure if mine is 50 or 55mm shocks yet but will measure them.
What can you do a set for? Need the complete kit with axle flip kit as well.
What drop will it give?
Will message you on Facebook
Kerbside Kustoms
- RKDesigns
In my case the Caddy has a 90mm drop in front and 80mm rear. And is a full kit vmaxx xxtreme with the adjustable dampers.
And also:
Caddyluv here @Caddy2K has the same set.
And also:
- Caddyluv
I’m on Vmaxx xxtreame and so far really good easy to fit and no troubles so far. My rears have two more holes to go lower and fronts probably another 30mm. You can adjust to softer that standard caddy suspension to rock hard, your preference. I got mine from RKDESIGNS, he will sort you out. Trustworthy. if you local pop down and see the set up if you want.
How much are we talking for this kit?
- RKDesigns
For full kit Vmaxx XXtreme kit click on the link: https://www.caddy2k.com/forum/viewtopic ... 12#p284212
Just fitted a full Bilstein lower kit and it's amazing, I'm my opinion well worth the money. Handling is excellent, I also fitted a camber kit to ensure even tyre wear.
- btaylor2k
Where about are you mate? I'm in Exeter
Made my mind up after dad was speaking with Ronnie that's the way I'm going...
Kerbside Kustoms
- Caddyluv
Wow bit far away I’m in Kent. But if you fancy a drive more than welcome.
