Hi everybody out there!
This is my first post, read all the rules and keen to speak to people. Based in Doncaster, just bought 2014 Caddy Max ready to upgrade radio. Can anybody help with this?
First Post
- Beaker2135
Re: First Post
Welcome
Plenty of people on here will be able to help with this. Popular OEM choices are RNS 315 & RNS 510 others have fitted Android or Apple Play
- hef355
Re: First Post
Hi mate, welcome and hope you enjoy the forum as indeed I have over the last couple of years! Help is always readily available by some truly genuine, kind and helpful experts! I’m still very much a newbie learner but if I can help with anything please askmcs211springer wrote:Hi everybody out there!
Re: First Post
hi thanks for your reply been on holidays just got back going to get on with it straight awayBeaker2135 wrote: ↑Mon Apr 30, 2018 8:09 am Welcome
Re: rns 315
hi just ordered rns 315 to put in my 2014 caddy max will i need new antenna and blue tooth module
Re: rns 315
hi just fitted rns 315 to my 2014 caddy maxi the antenna on the rns 315 as a twin coupling were as the caddy a single i have fitted it all working but poor on AM ? any ideas
Re: First Post
I admit I'm not an expert, but I have the same thing on my '06 Octavia. I think you can buy adapters to make it a twin input, I think the original idea was to have an 'alternative' signal in case of drop-out etc, which might explain the poor AM. I believe its called a fakra connector on the back??
Also, although you probably have found this out, depending on if you get the 315 or (i guess) 315+ (Amundsen+ in skoda terms ) then the blue-tooth is built in rather than needing the module.
Hope some of that may help.
