Noob rear camera pain...
totty79
Re: Noob rear camera pain...
Post by totty79 » Sat Jun 02, 2018 1:01 pm
He needs switched power to the camera as it's a one with lights on it.
Tp88
Post by Tp88 » Sat Jun 02, 2018 1:17 pm
Totally stumped by it.
So just to be clear...
1. (30) Wiper power
2. (86) Reverse light
3. (87)Camera power
4. (85)Earth
There’s also a rouge power wire coming from the plug in of the video wire to the head unit? Does that need power? I’ve tried it and it’s not made it better or worse?
The head unit has a can bus built in which is all the right settings to allow for the rear camera.
But regardless of all of the above I’m still getting this...Image
totty79
Post by totty79 » Sat Jun 02, 2018 3:21 pm
Run a temporary wire direct from the battery to the camera, if it clears then power source is the cause. If not then the power wiring is fine and the problem is elsewhere.
Tp88
Post by Tp88 » Sat Jun 02, 2018 6:53 pm
So I’ve just connected the camera directly to the battery and the image is the same... any other thoughts?
Liam
Post by Liam » Sat Jun 02, 2018 7:39 pm
dodgy camera ?
Build thread here
brooneye
Post by brooneye » Sat Jun 02, 2018 8:02 pm
maybe buy another
totty79
Post by totty79 » Sat Jun 02, 2018 8:07 pm
Do you have another camera with the same style of output that you can use to test?
Camera or video wire could be at fault.
Tp88
Post by Tp88 » Sat Jun 02, 2018 8:10 pm
Liam wrote:dodgy camera ?
Tried a spare camera and it still does the same!
totty79
Post by totty79 » Sat Jun 02, 2018 9:13 pm
In that case try plugging a camera direct into the head unit, there could be a problem with the video wire or the head unit itself, sounds like you've ruled out a camera or power fault.
horace01
Post by horace01 » Sun Jun 03, 2018 12:51 pm
Looks like an earth issue to me.
I'd be double checking your earth. Did you make a new earth point, splice into an existing earth wire or use an existing earth point?
Failing that as you have tried power direct from the battery I would agree the camera is probably at fault.
Sent from my Nexus 9 using Tapatalk
Tp88
Post by Tp88 » Sun Jun 03, 2018 3:03 pm
horace01 wrote:Looks like an earth issue to me.
Earth to the chassis won’t do? I did try to use the Earth from the wiper but it didn’t make a different :-/
horace01
Post by horace01 » Mon Jun 04, 2018 12:15 am
Earth to chassis should be fine. Did you remove the paint from the chassis?
Sent from my HTC 2PS6200 using Tapatalk
Post by Doc » Mon Jun 04, 2018 5:19 am
Try removing the ground connection at the back door entirely. The headunit jack plug and the ground connection you've taken at the back door are quite possibly causing a ground loop.
Post by Doc » Mon Jun 04, 2018 5:22 am
Does the relay chatter when you have the engine running and engage reverse? Because of the power supply for the reverse lamp being dimmed, it may be momentarily dropping out the relay.
Philfab
Post by Philfab » Mon Jun 04, 2018 2:12 pm
Just to add into this, I've just fitted the reverse camera (Chinese Ebay special), all worked fine after tapping power into the rear light block.
(Blue/Black = Power & Used brown for earth) then i read this and as soon as i started the engine the camera image flickers.
So not just you.
