Micro scratches on cluster
- Caddyluv
So When I got my van I knew it was a site van so when I took everything off if was full of sand and grit. The cluster has been scratch since day 1 but it is now driving me crazy. Anyone know how to fix it.
Re: Micro scratches on cluster
- Liam
could you just replace it from a good set ? mine are in a similar state hard to know what to do with them
Build thread here
Build thread here
- Caddyluv
There you go again throwing money away. It works well. Just need elbow grease. ♂️
Thanks Doc.
Thanks Doc.
- Caddyluv
Ordered. we will see.
- dizzee stuff
T cut works a treat I have done a few sets now.
- Caddyluv
I’ve only got 3m fast cut. To abrasive maybe.
- dizzee stuff
never used that so couldn't comment
- Caddyluv
- Bluesie
Mine is the same. It drives me mental as well. It will be interesting to see what works. I had contemplated replacing mine but I'm not sure how much a new one is or how easy to fit.
- Bluesie
Hi Doc, could you please tell me which product is recommended in the thread? I'm unable to view it.Doc wrote: ↑Fri Jun 22, 2018 2:14 pm This topic has a product I find works great.
viewtopic.php?t=22094
- Afield23
I used Meguiars Scratch X (think that's what it's called). Worked really well on a deep scratch I had
- Caddyluv
Hey mate it’s called Xerapol I’ve just ordred some. I will let you know if it works.Bluesie wrote: Hi Doc, could you please tell me which product is recommended in the thread? I'm unable to view it.
- dan@biali
I used the same product and it does require a lot of elbow grease and if I remember correctly the results weren't amazing. I ended up using a mini polisher (rupes nano) and their brand of polishes/pads and with the cluster out of the dash went to work on it going from heavy cutting through to refining. Took quite a long time but its possible to remove quite deep scratches.
