Interior shelf
Interior shelf
Just wondering had any one painted there shelf in the cab and how does it look? I'm thinking of carpeting the roof lining and wanted it all black inside?
- Caddyluv
Re: Interior shelf
Loads of people have. Just use the right stuff. I’m getting mine trimmed but I’m doing the other bits to.
Prep.
Light coats.
Prep.
Light coats.
Re: Interior shelf
Are they Upol products CaddyLuv?
Edit: Zoomed in on the pic and can see that they are
- Caddyluv
Re: Interior shelf
Yes mate. Scotch pad, wipe clean, adhesion promotor, mid grey paint. Not a perfect match. But closest your get.
- brooneye
Re: Interior shelf
Here’s mine
Carpeted headliner
Lower shelf sprayed gloss black
Other trim pieces also sprayed gloss black
Carpeted headliner
Re: Interior shelf
Can you spray the headliner? Or is retrimming the only option ?
- Caddyluv
Re: Interior shelf
How hard is it around that interior light part when carpeting. I’m bowing out I’ve got a trimmer to do mine. I had a go. It looked crap. I have to learn my limits♂️
- brooneye
Re: Interior shelf
@caddyluv I sent mine to the trimmers and it was done in black 4 way stretch carpet. I also sent all the plastics to the Bodyshop I use as my theory was I would be cheaper and I know there wouldn’t be any runs
- Caddyluv
Re: Interior shelf
Fair enough light coats is the answer won’t get runs.
Re: Interior shelf
The carpeted area around the interior light is cover by the parcel shelf so I wouldn't worry if it didn't look good when carpeted.
I just dyed my headliner last week, saves adding bulk and causing other trims to misalign when refitted.
- brooneye
Re: Interior shelf
Have to got it back in yet?
Re: Interior shelf
Yea, went back in a hour later.
Doesn't take long to dry in this weather.
- Caddyluv
Interior shelf
Your roof lining DOC did you cut the loops that’s ment to go over the bulk head to get it out easier or am I just not seeing them in the picture.
Re: Interior shelf
Yea, I was on my own and had nobody to pull the bulkhead back to get past it. I wasn't gonna go taking it out.
- Caddyluv
Re: Interior shelf
I took it all out thinking it was important ♂️ took me longer to that than it did the take the rest apart.
