Hi All if anyone could help I’d appreciate it
I’ve got a 2015 startline caddy maxi, with the standard RCD210 aux in stereo, am I right in thinking that the RNS315 if it has a MAC address has internal Bluetooth fitted? And all I need to install into my caddy is the external gps aerial, the microphone and wiring harness and a new internal light with microphone fitting ? Or a dab aerial if the unit is dab. And VCDS to code.
Is the RNS315 the only vw stereo with internal Bluetooth ?
Matt
Retrofit RNS315
