bulb error light coding
- sheepy92
is there anyone midlands based who would be able to code out my bulb error light cheers folks
Re: bulb error light coding
LE65 1TE any good?
Last time I said I was in the Midlands I was told is East Midlands so make your own mind up on that.
What bulb error?
What year caddy?
What bulb error?
What year caddy?
- sheepy92
hi doc its a 2013 63 caddy and i have changed the rear lights for facelift and now a connection missing causing a open circuit on rear lights
@Doc
I will have access to VCP for a short period and need the steps to code the bulb out error for the DRL/park light only.
I have a Caddy4.
I have a Caddy4.
Use the guided functions and then select "other". You'll see pq35 BCM codings option.
Ok thanks @Doc
Is the process thereafter self explanatory?
Yes buddy, you read your BCM, check the diagnostics boxes for the relevant outputs, write the new configuration and you're done.
Cheers doc
@Doc
So i borrowed the VCP cable and I’m struggling to solve this.
When I used the guided functions it was the “Apps” menu that had the BCM outputs settings
I unchecked the DRL diagnostics and the standing (park) lights as well but no luck with the bulb error. Below is the pics before any changes made
Any advice?
Any advice?
I have same issue on my 2014 caddy, had the MK4 lights installed, but they could not code in bottom bar on lights, and bulb light stays on in the dash, the thing is I don't have access to VCP, so if anyone close to Cambridge can help, or I don't mind travelling to get it sorted, thanks
if u don;t mind travelling to Hemel Hempstead, I can helpdaz-uk wrote: ↑Sun Aug 04, 2019 4:54 pm I have same issue on my 2014 caddy, had the MK4 lights installed, but they could not code in bottom bar on lights, and bulb light stays on in the dash, the thing is I don't have access to VCP, so if anyone close to Cambridge can help, or I don't mind travelling to get it sorted, thanks
I have genuine VCDS, VagCAN Pro, SMOK and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
Any assistance with my situation. I already have a borrowed cable
I've never had a problem with the VCP method for LED DRLs. What brand LEDs did you use, they are the correct 5/21w base?
The LED bulbs are osram original as pic below. They don’t claim canbus error free so I knew it will show the bulb out error.
They work well as DRL/Park lights by dimming etc properly apart from the bulb error.
I think I’m not doing something right in VCP.
My question is what settings do I actually uncheck on the VCP?
Also with VCP there are options on the home page to select CAN and K line etc so not sure if this is the issue.
Evening! Hope you can help. I've just got a caddy 64 maxi and fitted led bulbs as drl. The warning light appears and only shows the left side as a fault? Changing the bulb to the right hand side doesn't change it? Any advice would be great!
