HI ALL
I have a 2011 tdi caddy and my headlights wont turn off. Every time i start the car my main headlights turn on and when i try to turn them off using the headlight switch nothing happens. i have checking the fuses they are all good i have checked the headlight switch and it seem to be on because of the light behind it when i took it out to check it please helpp any advice would be good and appreciated
kinda regards
PLEASE HELPP Headlights wont turn off
Re: PLEASE HELPP Headlights wont turn off
The Central Electrics Control Module (CECM) or Body Control Module (BCM) will fail to the safest state if something is wrong in a circuit. This might be the module or just the light switch itself.
Easiest check is to swap a lights switch from another caddy of the same spec into yours to check. Otherwise, a diagnostic check with VCDS or similar will point you in the right direction.
Thnaks Doc
i will investigate your suggestions
thanks again
thanks again
