has anyone got any pictures of how they have put a long strip of led lights in the roof and also how they are wired up cheers
Sent from my SM-N950F using Tapatalk
Rear interior light ideas?!
- Markham92
- Caddyluv
Re: Rear interior light ideas?!
Lighting the rear is pretty much endless you can pretty much do what you want. LEDs decking LEDs disco dancing ones might be able to put a mirror ball in. What do you want it for. Design or for practicality, just a white light. Do you want it hidden or on display?
Mines simple but affective.
- Markham92
I just want it t0 be bright in the back as I transport all my fishing gear around and can hardly see anything when the light is on just looking for good easy upgrade if there is one bud
- Caddyluv
Then yeah easy. Pick up some white LEDs I will put up a link. Then just wire it to your middle light. 6 or 8 that’s a neat way. Or you can buy a LED strip light from vanstyle I think. Or just go on eBay and pick up so strip LEDS.
I like these because they are just male and female connections and really bright with stainless case.
Double LEDS.
https://www.wholesaleledlights.co.uk/wh ... -40mm.html
Single LEDs.
https://www.wholesaleledlights.co.uk/wh ... -15mm.html
Then I just connected to the light switch.
Double LEDS.
Single LEDs.
- kefconstruction
What size wire did you use for the light part?
Sent from my G8141 using Tapatalk
- Caddyluv
The wire that came on these decking lights. Couldn’t tell you the size. Sorry.
