BJB/BLS to ASZ SWAP
Bumblebee58627
BJB/BLS to ASZ SWAP
Post by Bumblebee58627 » Sun Sep 23, 2018 11:25 pm
So my motor threw a bearing... I have read the article on vwcaddy.com on how to do the swap.
I have a few questions that i couldn't find in any other forums.
Here is the question, if my van already has stage 1 tune on. Do i still need to map it for the ASZ? Or how does the tuning situation work?
I don't want to use the bjb injectors or turbo on the ASZ.
Sent from my FIG-LX1 using Tapatalk
2007 1.9 TDI Caddy Panel Van (Pre Facelift)
1994 Golf Mk1 16V
1989 Caddy mk1 2L 8v
1974 Beetle , named Bumblebee (my first car and my show car) Slammed to eart
Re: BJB/BLS to ASZ SWAP
Post by Doc » Mon Sep 24, 2018 5:03 am
When you do a ARL/ASZ conversion in place of a BLS you have the option to keep your standard (BLS) turbo and injectors or use one or both from the replacement engine.
If you use your original parts your ECU map will be fine.
If you fit the parts from the replacement then you will need the injection/boost maps adjusted accordingly.
Bumblebee58627
Post by Bumblebee58627 » Mon Sep 24, 2018 6:08 am
Thanks Doc.
So it's not just a tune?
Does it have to be adjusted with the vcd's?
1994 Golf Mk1 16V
Bumblebee58627
Post by Bumblebee58627 » Sat Oct 06, 2018 11:00 pm
Can someone help me please??
Do i still need to do the modification to the block of the ASZ if i have a BJB engine in my van?
1994 Golf Mk1 16V
torque777
Post by torque777 » Tue Oct 09, 2018 9:39 pm
Yes bjb and bls have a sensor mounted to rear of crank so any asz or arl will need the crank case modified
Bumblebee58627
Post by Bumblebee58627 » Wed Oct 10, 2018 5:50 am
torque777 wrote:Yes bjb and bls have a sensor mounted to rear of crank so any asz or arl will need the crank case modified
Thank you torque777,
1994 Golf Mk1 16V
AaronC92
Post by AaronC92 » Mon Oct 15, 2018 7:25 pm
Also the cam pulley and cam position sensor will need to be swapped over, I had this trouble on the weekend put it all together and then had to take the timing belt back off to change the cam pulley over.
Bumblebee58627
Post by Bumblebee58627 » Tue Oct 16, 2018 8:06 am
Thank You Aaron
I am doing all that this weekend. But I am stuck on driveshafts and gearbox mounting (the one on top of the gearbox, with the 3 hole)
Which driveshafts will work on the 6 speed conversion?
I've been reading mk5 driveshafts. Will any driveshafts from a mk5 6 speed work?
1994 Golf Mk1 16V
Post by Doc » Tue Oct 16, 2018 8:23 am
I may be wrong but the gearbox mount is probably the same as your BLS unit used, you might be unfortunate and have a two hole version in which case you'll need to get a three hole.
The standard from when mk4 6 speed gearboxes were a common but new popular retrofit on the Caddy2k, the mk4 6 speed shafts were used with the original caddy outer CV joint.
More recently, people have been using mk5 6 speed shafts which they say bolt straight in and are the correct lengths.
Bumblebee58627
Post by Bumblebee58627 » Tue Oct 16, 2018 8:39 am
That's what the top of my gearbox looks like. How do i look for the code on the gearbox?
Will any 6 speed mk5 driveshafts work?
Are the splines for the hubs the same? Image
1994 Golf Mk1 16V
Post by Doc » Tue Oct 16, 2018 8:43 am
The flat surface facing up (left of the blue spot in your photo) should have the gearbox code stamped on it.
You are missing the mounting plate which goes between the gearbox and the chassis mount.
They do tend to crack so a new one from VW might be your safest option.
I've not used mk5 shafts but the hubs are all the same so splines will match.
Bumblebee58627
Post by Bumblebee58627 » Tue Oct 16, 2018 8:50 am
Thank you so much Doc
1994 Golf Mk1 16V
Novakid
Post by Novakid » Thu Mar 07, 2019 4:48 pm
Anyone on here completed the BLS to asz conversion?
I am looking for some more detail.
Any help would be appreciated.
ferda5
Post by ferda5 » Fri Mar 08, 2019 5:45 am
BLS,BKC,BJB,ABQ has a crankshaft sensor in the clutch area ... ASZ has a sensor in the oil ... a sensor opening must be made to the engine block in the clutch compartment.Install the sensor sensor, replace the camshaft wheel with the sensor
ferda5
Post by ferda5 » Fri Mar 08, 2019 5:47 am
I kept the gearbox original
