BJB/BLS to ASZ SWAP
Adie66
Re: BJB/BLS to ASZ SWAP
Post by Adie66 » Thu Aug 01, 2019 9:11 pm
I dont think you have any problems thsts the only issue ive got with mine other than that its fine think im only having problems because ive took the head an had redone lol
Thats mad ive got metal plate in my leg 10 screws thats all coming out only had mine in for just over a year irritates me like mad got a screw sticking out my ankle thats just a swine haha
Azz03
Post by Azz03 » Thu Aug 01, 2019 11:07 pm
Adie66 ahh yeh true that could be a reason may be a slight bit of difference in the how it used to be. I’m sure you’ll figure it out you managed the conversion without any help lol.
Yeh there a right pain I’ve put my op off twice now as I run my own business and don’t want to be off work.
I forgot to ask you what size is the bayonet connector you’ve put in the turbo boost pipe you made direct from the turbo if you get what I mean
Adie66
Post by Adie66 » Thu Aug 01, 2019 11:23 pm
Yeah il get there in the end haha
Ive not bin able to work due to my leg an the screw in my ankle sticks out so cant wear boots an my leg aches constantly hopefully this will help
I know what its like putting things of but just gets worse the longer you put it off
Ill have a check ive got the receipt somewhere with the size can rember of top of my head
Azz03
Post by Azz03 » Fri Aug 02, 2019 5:48 am
Adie66 I’ll get it sorted eventually yours sounds worse than mine so I can manage for a little longer haha
Cheers mate
james400
Post by james400 » Fri Aug 02, 2019 8:30 am
Adie66 wrote:Hopefully this vid works this the noise my engines making //cloud.tapatalk.com/s/5d42e91e617 ... WA0002.mp4
Cant seem to open it to listen to it mate I have a Simla described noise on my old engine
Adie66
Post by Adie66 » Sat Aug 03, 2019 8:57 am
James i dont know why azz has bin able to watch it i had trouble uploading it kept saying unsupported format dont know why ive got a brand new Samsung s10 so should be easy but cant seem to do it proper
Adie66
Post by Adie66 » Mon Aug 05, 2019 3:21 pm
Bit of an update spoke to my engine shop he said that its a diesel nock an thats why im getting loads of smoke so something to do with the injectors
I dont realy know anything bout the injectors on these
Novakid
Post by Novakid » Mon Aug 05, 2019 7:12 pm
Adie66 wrote:Bit of an update spoke to my engine shop he said that its a diesel nock an thats why im getting loads of smoke so something to do with the injectors
Is it a asz engine pd130 ?
Very easy to change out
Azz03
Post by Azz03 » Mon Aug 05, 2019 7:24 pm
Adie66 I sort of had a feeling with the smoke it would either be injectors or turbo but your turbo is new so maybe the injectors could do with a clean, it’s very strange it can almost be soul destroying knowing you’ve done everything the right way but yet something has popped up to challenge you lol.
Azz03
Post by Azz03 » Mon Aug 05, 2019 7:25 pm
Novakid you’ve done the asz conversion as well haven’t you? Or am I thinking of someone else lol
Novakid
Post by Novakid » Mon Aug 05, 2019 7:56 pm
Yeah I am almost done Still have the timming belt and water pump to replace before it goes in.
Hangging of the garage rafters just now lol
Novakid
Post by Novakid » Mon Aug 05, 2019 7:58 pm
You running pd130 injectors?
Azz03
Post by Azz03 » Mon Aug 05, 2019 8:08 pm
Novakid yeh I thought you was I’m sure I remember reading it somewhere on here. Haha pretty cool idea yeh I’m running the pd130 injectors and turbo
Novakid
Post by Novakid » Mon Aug 05, 2019 8:15 pm
They may just need a clean or new seal kit for the injectors?
Very easy to remove, biggest problem is that you have to replace rocker bolts and injectors bolts as the are stretch and heads up not cheap to replace from Vw .
I have been told that you can reuse them but don't carry out the extra 90 or 45 turn to stretch on torquing.
Darkside sell a full set non stretch for about £45
If the injector or injectors shot I have a full set that I removed from my asz because I am running bls ones.
Azz03
Post by Azz03 » Mon Aug 05, 2019 8:53 pm
Novakid yeh I said the same to adie66 about his injectors I’m not up and running yet got turbo boost pipe and belt to sort then remap it job done hopefully lol
