BJB/BLS to ASZ SWAP
Novakid
Re: BJB/BLS to ASZ SWAP
Post by Novakid » Fri Mar 08, 2019 10:56 am
Thanks for that.
Have u carried out the conversion yourself?
ferda5
Post by ferda5 » Fri Mar 08, 2019 11:04 am
Yes, he did. The new sensor needs to be pressed onto the crankshaft with the tool
Novakid
Post by Novakid » Fri Mar 08, 2019 11:14 am
If you don't mind answering a few details I am missing that would be appreciated..
The part I am struggling with is what has to be moved from Bls to asz?
so for now I am keeping the original 5 speed.
Parts I know u have to swap.
Exhaust manifold, turbo, injectors, camshaft pulley, egr and cooler I believe.
Parts I'm not sure- Oil filtter housing, oil sump, bottom pulley from crank,
can I use the bls flywheel and clutch?
Thanks for you're help.
Novakid
Post by Novakid » Sat Mar 09, 2019 9:56 am
Anyone????
Bumblebee58627
Post by Bumblebee58627 » Mon Mar 11, 2019 8:41 am
if you have any pictures of the conversion would you
You mind sending me them to my email
smackie_240@yahoo.co.uk
If you buying complete ASZ engine, you dont need to swap anything over except , crank pulley , cam pulley and you will need the downpipe from a ASZ.
you can use the BLS clutch and flywheel if you keeping the 5 speed.
2007 1.9 TDI Caddy Panel Van (Pre Facelift)
1994 Golf Mk1 16V
1989 Caddy mk1 2L 8v
1974 Beetle , named Bumblebee (my first car and my show car) Slammed to eart
ferda5
Post by ferda5 » Mon Mar 11, 2019 6:45 pm
I bought a bare engine and disguised everything. The crankshaft gear does not need to be, the oil bathtub must remain in the ASZ. I changed the oil filter holder too, the water cooler is different
Novakid
Post by Novakid » Sat Mar 16, 2019 11:11 am
Thanks for all that.
Sorry about all the questions i am sure they have been asked 100 times.
So just to be clear (Stickler for deatil)
I buy an asz engine.
I put my BLS exhaust manifold turbo,oil filtter housing the cam pully (not crankshaft pully) bls injectors new bls crankshaft seal with modifications to block.
That's it ?
I dont have to modify any wiring plugs or extra pipes?
Azz03
Post by Azz03 » Thu May 23, 2019 11:05 pm
Hi guys
I’m in desperate need of some help a friend of mine and my mechanic was part way through my asz conversion but due to some sad circumstances he passed away so I’m left with a few bits left to get it running.
My first one is the cooler hoses that go into the heater matrix one of them is two short and is slightly kinked and the other one is two long which makes it kinked on the bend.
Also because I’ve used the pd130 turbo it’s lower down and I need to run pipes from
The turbo to the front of the rad how do I go about this.
I’d really appreciate it if someone could help me as I currently have a van just sitting there.
Thanks in advance
