I've picked up a phoenix 250.1 amp and 8" basscase but hit a bit of a brick wall...the standard RCD310 stereo doesn't have an output for an amp....I was hoping to just splice off the standard speaker wiring but been told that's a no-no.
Is there an adaptor I can buy or is my only option a new headunit?
RCD310 Phono output for amp?
- Joeski
Re: RCD310 Phono output for amp?
https://www.caraudiocentre.co.uk/produc ... -22749.htm
Buy one of these, if you don't have rear speakers connect the rear speaker feed to this then you have you Phono for the amp....
- Joeski
nice one dude, i found the same thing on ebay after some hunting...i don't have any cabling going to the rear speaker outputs so i presume just connecting to the front speaker cables will be ok?
