GAZ, ST or Bilstein for Maxi Kombi?
Looking to drop my Maxi Kombi, but unsure how 'cheap' I should go...
Cheapest I'd go is probably GAZ from Vanstyle at £500 https://www.vanstyle.co.uk/van/caddy-he ... -6695.html
Next up is the ST kit from Darkside at £525 https://www.darksidedevelopments.co.uk/ ... g-kit.html
Then the 'Gucci' option is the Bilsten kit from Darkside for £900 https://www.darksidedevelopments.co.uk/ ... g-kit.html
Does spending almost double on Bilstein get me a) double the performance and/or b) double the reliability?
I know they all say not for Maxi's, but from what I understand that's because of max load ratings? Mine is generally run without rear seats, and only ever really carries mountain bikes - 60kg load at most... That's ok, right? When i spoke to Darkside last year about it, they seemed to think so.
I'll need new top mounts also i guess...
How easy a job is it to DIY, without my own ramps or owt?
Re: GAZ, ST or Bilstein for Maxi Kombi?
Dont forget darkside is plus vat!
uuuuuugh... might avoid the Bilsteins in that case!
- Joeski
yep don't forget the Vat!!
I went with KW for my caddy, was amazed (as was the mechanic) with the quality of the items and plushness of the ride for the price paid. For the next week I kept forgetting it had been lowered because the ride was so smooth, really surprised.
Can't speak for lasting quality, but these have been on for over 12 months and covered around 15k and look/feel as good as the day i had them fitted...and I live in a city FULL of speed bumps and potholes. German made, from the same factory that produce real high-end kit so I have no reason to believe they'll fail any time soon.
So yeah....you probably guessed they get my vote
Really interested in this feed, I have exactly the same predicament right now. Swaying towards the st kit even with the vat!
- torque777
I fitted vmaxx to my maxi life and regretted it, was way too soft I now run spax rsx front coilovers and gaz rear dampers with darkside rear lowering kit, I like the fact you can adjust the firmness to suit your driving.. Gaz have been on three years but needed servicing after two, but that's the best thing as they are not a throw away item.. Spax are brilliant and still feel as good today as they did 30k ago when new, still look good too and the adjustment knob is on bottom so really easy to adjust
The st kit is a sub brand of kw and this shows in quality, Iv had mine on coming up a year and still feel spot on.
Ricksy1121 wrote: ↑Wed Oct 10, 2018 6:25 am The st kit is a sub brand of kw and this shows in quality, Iv had mine on coming up a year and still feel spot on.
Not had any of the others to compare them to but I’m happy with st.
- JD2k
I've just bought the ST kit after looking through reviews on here, should be around £250 to fit and then new top mounts needed as well.
Thanks all
anyone got a link to the relevant KW kit? If ST is basically KW, i guess that might not be a bad shout...
fair to assume then that self-fitting isn't super easy? i've a couple of mates who can wield a spanner!
- JD2k
- JD2k
I had quotes both from Darkside and Awesome Gti, both said the van will be in for the whole day to have the kit fitted so I reckon a good 4-5 hour job
Cool - guess I'll try to find the one closest to Bristol!JD2k wrote:I had quotes both from Darkside and Awesome Gti, both said the van will be in for the whole day to have the kit fitted so I reckon a good 4-5 hour job
- Joeski
This is the one you want and you might as well go for new top mounts whilst you're at it.
The only difference with the ST compared to KW's higher spec kits is the type of steel they've used I believe. Structurally exactly the same but more prone to rust when exposed to the elements, so keep them clean and in theory they'll last
- Hudson97
I took mine to Darkside and got the ST X kit fitted, dropped it off at 8am and it was done by half 11. Feels spot on. It still could go lower, they said they just set it to what they normally put it at on caddy’s, so not sure how much lower it is. Would definitely recommend
