Caddy life double middle seat
Hello I have just purchased 2010 caddy life maxi I can’t get the double middle seat to lift up and fold against the passenger seat has anybody know what could be wrong with it thanks
- mark1a
Re: Caddy life double middle seat
Do you have the lever near the floor on the outer edge, and can you see if that’s working?
Hello Mark it’s not a lever it’s a loop of webbing I pull It makes a click but the seat will not move the single seat lifts up easy
I think there is one each side? Have you folded the back rest bit down first? Mine sticks sometimes
- mark1a
There's a webbing loop for each seat (1x & 2x), pulling this should allow the seat backrest to go down, and then a small plastic lever near the floor which allows the seat bases to fold forwards toward the front seats; these can either then be secured to the floor with bars that clip into the floor holes, or removed completely by pulling a further lever bar under the seat to unfasten them.
BTW I've only described what my own is like (mk4), assuming mk3 is the same process, hope this helps.
- mark1a
Thanks Mark that works I have been pulling the webbings at the back of the seats
- mark1a
Nice one, cheers and welcome to Caddy world.
