HELP NEEDED! Fuel «Flap» stuck open!
Larjenen
Post by Larjenen »
My mother was loaning my van, today, and was going to be nice and fill her up, but when she was going to close the fuelflap again it wouldnt close.. Anyone had a problem like this? Ill post some photos..
Its a 2008 VW Caddy 1,9TDI
Larjenen
Re: HELP NEEDED! Fuel «Flap» stuck open!
Post by Larjenen »
Caddyluv
Post by Caddyluv »
It holds on by two little bolts. Pull it off. I recon you might just have a bit of grit stuck or something, take it off so you can have a really close look. Spring might have moved something like that. It’s what I would do.
Larjenen
Post by Larjenen »
Caddyluv wrote:It holds on by two little bolts. Pull it off. I recon you might just have a bit of grit stuck or something, take it off so you can have a really close look. Spring might have moved something like that. It’s what I would do. Image
Its fixed now, the problem was the place the spring connects to the flap, it was bent so it wouldn’t fit through the hole. I simply bent it until it fit :)
Caddyluv
Post by Caddyluv »
Yeah something simple.
