My mother was loaning my van, today, and was going to be nice and fill her up, but when she was going to close the fuelflap again it wouldnt close.. Anyone had a problem like this? Ill post some photos..
Its a 2008 VW Caddy 1,9TDI
HELP NEEDED! Fuel «Flap» stuck open!
- Larjenen
- Larjenen
- Caddyluv
Re: HELP NEEDED! Fuel «Flap» stuck open!
It holds on by two little bolts. Pull it off. I recon you might just have a bit of grit stuck or something, take it off so you can have a really close look. Spring might have moved something like that. It’s what I would do.
- Larjenen
Its fixed now, the problem was the place the spring connects to the flap, it was bent so it wouldn’t fit through the hole. I simply bent it until it fitCaddyluv wrote:It holds on by two little bolts. Pull it off. I recon you might just have a bit of grit stuck or something, take it off so you can have a really close look. Spring might have moved something like that. It’s what I would do.
- Caddyluv
Yeah something simple.
